The best bushings and mounts E9X E8X
RSFB feedback::
Just put in the Bimmerworld solid aluminium subframe mounts. Rear end is rock solid. I can't feel any added NVH at all.
They cost less than $300, though the install cost IS higher unless you have an extensive shop at home as they had to be pressed in. Not something you can easily do in your garage IMO.
After driving cars and mine with various setups, I dunno why anyone would bother with anything other than 1. Stock, 2. White line inserts, or 3. Solid aluminium.
Anything else is just an expensive compromise.
I agree. They should have come solid from the factory like the next gen.
1,923
662
RSFB feedback::
I wish I went solid i was scared of nvh so did white line poly and they are great but i would think Turner or any solid would be better. Maybe I'll do those 2 piece solid ones so I don't have to press anything in
Mikejones1208
145
115
Savannah, GA
2009 BMW 335i
The condor bushings i used were solid 2 piece, was able to install them at home no problems, a little persuasion from my dead blow hammer was all it needed! And to clarify my earlier post, both subframe and diff bushing combined were 300 dollars.
SJ_1989
368
299
Illinoisssss
2008 E90 335i
Just as an FYI...
I recently bought the Turner solid engine and trans mounts. Wanted something rigid because the turbo on my docrace kit sits VERY close to the strut tower (more than I would have liked given the money of the kit) and, well, bcracecar. It's not specified on Turners website but it will drop the engine 5 mm and the trans 1 mm per the documentation sent with the mounts.
EDIT 2019-02-21:
Want to correct my previous statement. Installed the Turner solid mounts and the engine mounts raised the engine if anything. Definately didn't lower by 5 mm like the documentation said.
Reactions: AWCR1MC
Panzerfaust
635
438
Chicago
E92 335i
https://www.fcpeuro.com/products/bmw-shock-mounting-kit-monroe-907984
Anyone used this kit yet? I had to order some stuff from FCP anyway and I'm working on a drag suspension setup so I stumbled across these guys. Really looking forward to them considering our stock ones are a crappy foam and as I've learned from @barry@3DM poly should stay away from my suspension. Most dedicated drag shocks come with a similar rubber mounting bushing so I'm curious to see how these will work out. With guys running low 11s and 10s on stock turbos now, I need to speed up my build and see what these 1Ks will do at the strip on a proper setup.
R.G.
668
328
Henderson, NV
E92 335, F10 M5
I run those. Inexpensive replacement solution for the stock foams
I believe Turner just released something as well.
Edit: Here you go
Panzerfaust
635
438
Chicago
E92 335i
Edit: Here you go
Yep, I actually just ordered those too- although the monoball upper mount mostly takes place of the bump stops and bottom rubber piece from the looks of it so I can still put the monroe mounts to work. I'm interested to see how having both monoball mounts and the rubber "tophat" with drag shocks will make the car perform at the strip. Hoping for numbers more in line with what a 600+whp car should be lol
R.G.
668
328
Henderson, NV
E92 335, F10 M5
The monroes will give a little more travel.
The few times I've dragged the car I noticed that the rear end tends to rebound too fast causing traction issues. I adjusted compression to allow the car to squat about 75% of what it wanted to and tried not tot let it rebound too fast. Car is more of a highway assassin unless you swap a trans suited for the strip tho.
Stokes
284
190
Houston, TX
2011 BMW 135i
@Mikejones1208
Thanks for sharing!
This material is suppose to be better use than delrin for nvh in the subframe. Decided to try them out as well. Will report back after they get installed.
Mikejones1208
145
115
Savannah, GA
2009 BMW 335i
@Mikejones1208
Thanks for sharing!
Ive been running them for awhile and theyre great, no increase in nvh at all with subframe bushings, definitely hear some gear whine though with the solid diff bushings
Reactions: Stokes
1,634
I’m finally getting ready to redo the rear end of my 335xi E90, and have the UHMPE rsfb from Condor Speed Shop. I’ll be throwing them in the freezer first to shrink them a little which should greatly help with the install.
AzNdevil
605
291
Hong Kong
poly bushings go in easily..... its solid alu ones that are a pain to install....
but the hardest part of everything is getting the stock bushing out lol GL
Reactions: JohnDaviz
They were pretty easy to install. No need to freeze. Just be 100% certain that they are orientated correctly before fully seating them though, because once they are in, they do not come out.
AshwinLB
39
26
Toronto, Canada
2008 135i 6MT "Narrowbody 1M"
I agree, no need to freeze, they went in really easy for me. The eBay tool made it really easy to remove the old bushings as well
