Ad: Revshift N54 Motor Mounts
Panzerfaust
637
439
Chicago
E92 335i
Yeah I saw they use the material for those and wondered if they could.
Since it's for a 95% track car, I thought it might be nice to be able to swap to softer inserts for the 5%, otherwise billet mounts it is.
@Revshift you guys could certainly capitalize on this, and itd be awesome for all of us!
It'd make your mounts even more unique imo since theres already at least one other vendor offering swappable poly engine mounts for the e9x (Turner, possibly BFI too?) But no good alternatives to metal engine mounts for a solid mount yet. Capitalize capitalize capitalize, please!
3,624
I don't get the whole swappable mount things. Seriously, who on earth is wasting their time to do this? And for what benefit?!
Panzerfaust
637
439
Chicago
E92 335i
I wouldnt swap them back and forth personally, but I know that being able to swap and rebuild the mounts is one of the things Revshift uses as a major selling point, and we dont have any solid mount options other than aluminum as mentioned above. If anything the "swappability" thing is just nice because you dont have to buy an entire new set imo, I could just rebuild them if the PU/U/whatever gets deformed.
Reactions: fmorelli
2,197
I think it is also nice to know you don't have to buy a new set of motor mounts and then try and resell your old mounts. Like if you went too aggressive(or too soft) and you want a different compound you can buy the different pucks and install them. A modular motor mount if you will. It's a smart design imo.
Reactions: Panzerfaust
3,624
IMHO with poly 9 out of 10 times it is going too aggressive. Just don't lol
Here's a simple way to pick. Call a friend over. Stand with your feet spread about 18" apart. Have your friend kick you in the nuts. If you get up in 20 seconds or less, get the harder bushings. See ... no need to have to change to less aggressive bushings - that test is foolproof :grimacing:
But agree with the ability to replace if worn out, etc, definitely a nice design.
2,197
Did you just assume my gender?
Panzerfaust
637
439
Chicago
E92 335i
If we had a good product made out of stiff rubber for engine mounts I'd probably go down that road, believe me. Itd be easier to match them with trans mounts if that was the case, but unfortunately it's either OEM (which I stuck with), PU or aluminum right now AFAIK.
Even though my car is more performance/strip oriented at this point, I still think the aluminum mounts would be overkill for me because my car does and will continue to see street use during any nice weather, plus the aluminum mounts for the N54 all drop the engine a bit I believe. I don't mind a decent amount of NVH in a high performance car so I'd be fine with PU/U/Delrin mounts for the engine or trans since we dont have that rubber option (unless you and Barry are cooking one up that wont melt lol), but I get where you're coming from especially in regards to engine mounts.
I have solid monoball shock mounts and hardly notice a difference on the NVH, to me it just feels like more connection to the road but shocks dont vibrate like a motor. I'll likely go with more solid bushings (especially monoball where available) for any other suspension upgrades though when that time comes solely due to performance, but my original post was made just because all the materials are right there as it is - yet theres no option for it which seems silly.
