Technical AzNdevil's RHD 335 6MT Build Thread
You've both got proper sleepers. I don't think my vehicles are modified enough to count as sleepers, but the factory look is what I want to stay with.
I was told by Birds that the ATB doesn't need a breakin fluid change.
Reactions: AzNdevil
AzNdevil
604
290
Hong Kong
tbh, i have no choice but to keep a relatively factory look as local police likes to pick on cars with exterior mods and tows them for inspection... which would be costly as my car doesnt pass smog even with all the cats in place.....
i might add a front splitter for more front grip as the car struggles on track but right now, cooling is a big issue and im piecing together an auxiliary radiator setup similar to @Asbjorn or upgrading my oil cooler again... or go dual oil coolers
havent completely made up my mind yet and im tempted to lower my coolant thermostat temp next time to see if i can workaround this...afterall its just for time attack and less is more...
diff fluid is cheap enough so i am doing it just for peace of mind ;)
Out of interest, why does it not pass smog with all the cats in place?
AzNdevil
604
290
Hong Kong
good question, i honestly have no idea
i suspect my second cats are contaminated because i have ran paint thinner and/or ethanol mixes before
even when i flushed the system with a few tanks of normal 93 fuel, it still wont pass smog
however, i only attempted to get it smogged during MOT a few times as the government was cracking down on friendly inspectors and
swapping downpipes to get the car inspected costs more than friendly inspections so... i reverted back to catless and parked my car for a few months
What are your thresholds for emissions (CO2 and NOx?) and what reading did it fail at?
For the UK MOT, both my cars pass without primary cats with a good 50% margin. If you have all 4 still in place then it should be even lower.
Drop me a PM and I can suggest some tune changes that'll reduce the readings. Should be able to sort that out.
AzNdevil
604
290
Hong Kong
thanks for the offer.... its been a few years since i tried to smog it officially so i dont even remember what the issue was
iirc HC was high for sure, CO is either too low or too high, something along the lines
i am running idle at ~14.9 afr and stock 6mt idle ~660rpm
we have two testing standards... one for yearly MOT which tests emissions at idle and a EPA rolling road test if you get caught by smog machines on the road side
AzNdevil
604
290
Hong Kong
lets see... for the past while i have been working on a few things
1. retrofitting a n20 oil pressure/temp sensor so i can get oil pressure readings. this is a digital sensor and only fits into the stock oil pressure switch location by stacking some washers. this also shows oil temp after my external oil cooler so it will be different to the readings taken from dme using the oil level sensor
2. installed a vdo coolant temp sensor + a m14 adapter to replace the cylinder head drain plug for coolant temps off the head directly (basically how the e36 guys do it) the gold sensor beside the knock sensor. the reading should be the same as the dme since stock readings are taken by the sensor on the oil filter housing
3. a tiny custom gauge to show all 3 items at a glance. this is 75% done. there are bugs on the display update due to my coding i need to fix.
todo:
1. need to add feedback to dme to trigger the low oil pressure light when it drops too much. 10 psi per 1k rpm should be enough. these engines tend to idle around 20-22psi when hot.
2. maybe replace the screen. its not readable under direct sunlight
3. make a custom housing for this. it looks too diy/ghetto
4. canbus module for integration to racechrono, allows for steering angle, throttle/brake input, speed, coolant/oil temps, and other data available on the canbus to be recorded into a racechrono session. watch the in car video for a demo of what can be done.
i have a ublox m8n gps module laying around so i will add this before my next track practice. need to add oil pressure logging as well
also evaluating if its worth the effort to add boost and iat logging into the mix but this requires a lot of effort
5. mdrive external module since my m3 szl doesnt like to advertise the correct messages to the dme and i want to get the shiftlights working on my dct m3 cluster. i have the module made and changed the code from superwofy's module to fit my use. just need to get it wired into the car but something cut my thumb open while i was trying to feel if there is still thread on the tire so i wont be able to do this until its healed
6. bought two sets of new old stock audison k4e speakers for front and rear, shitty e92 doors have a really shallow pocket for speakers so these doesnt exactly fit, it rubbed a hole in the foam barrier inside the door and wont allow the window to completely open (theres a 0.5cm gap). hacking of the stock tweeter pod in the rear is required to fit the upgraded tweeters.
i cant stand listening to anything but the radio with the stock top hifi speakers + l7 amp. i hated the stock sound system ever since i bought the car but my trips are usually ~30 minutes so i beared with it until recently when it became possible for me to drive to china. this means i will go on longer drives (1-3 hours) and i dont want my ears to suffer any longer.
i still havent 100% decided if i want to upgrade the audio system further in my car. its a deep hole to dig myself into and its unnecessary weight for my car. the l7 amplifer and underseat subwoofers could definitely use an upgrade.
7. broke the passenger door (rhd) handle while i was removing the door card to install the speakers, luckily the e90 rear left door handle fits but i cant reuse the stock cover cause its shaped a little bit different....
i will add details and pics and do a short write up when i can be bothered
also went to a different track for some practice sessions, heres some footage of my shitty driving
Full Send (This is what it looked like from the outside during the last few seconds of the In Car Lap video)
In Car Lap with data from canbus
AzNdevil
604
290
Hong Kong
wow....somehow the turner studs installed 4 months ago managed to all snap while i was driving on the highway....
i was going 100~120mph down the highway, something started vibrating so i stopped to check..
kicked the tires a few times but it was fine so i continued, vibrating started to get worse so i stopped again but still nothing....
i chickened out so i drove slower at ~40mph then boom. i heard something dragging on the ground and see my wheel flying off into the sunset.....poor wheel, it had to sit in the fast lane all by itself
couldnt call emergency services with my phone for some reason so i got my garage to help call them. stood at the side of the highway for an hour before a tow truck came and picked me up...took another hour for them to load my car up cause my rear end is sitting on the ground and they didnt have anything low enough to jack my car up... so they ended up dragging my car up pieces of wood until their jack fit and put everything on a dolly
riding down the highway on a flatbed is a new experience
kind of surprised my apex wheel survived this without new scratches
anyways.........the aftermath
rear left wheel hub with all 5 snapped studs. the stud thats sticking out has its threads destroyed. garage tried drilling out the other broken studs but failed
brake dust shield took most of the damage
minor scratching on the brake disc since it did drag on the ground
luckily everything else was fine
oh and i found out why my rear clunks when going into reverse....turns out my cl brakes rc5+ brake pads fell apart after a few track sessions.....
ended up replacing both rear hubs + bearings, rear left brake dust shield, both rear rotors, rear brake pads and going back to normal bolts for the rear.... i still need to figure out a solution for the front since standard bolts are too short and extended bolts are too long
this is not the first time i have had wheel studs snap on me. i installed these turner studs because one of the apex studs i was using snapped before my first track session. to be fair, these were ~6 years old and since they are supposed to be replaced every year or so, this is on me.
my thumb still isnt healed completely so i couldnt get my m drive arduino module installed. i will be going on vacation this week so it will have to wait until im back...
AzNdevil
604
290
Hong Kong
WTH, glad you're ok.
thanks im still alive :)
i am kind of annoyed now since i wont make the track day in two weeks now that a bunch of issues show up but i am leaving for vacation tonight....
need to deal with the front studs as i dont trust them for the track anymore
trying to quote/buy high friction rear brake pads has always been a big pain in the ass
on top i need new tires and an alignment.........
858
Any thoughts on what caused this? Straight up defective studs? I've never heard of somebody's wheel actually falling off.
AzNdevil
604
290
Hong Kong
honestly no idea.... most likely the studs werer shit and the nuts backed out somehow and everything vibrated until they snapped...
studs were ~3 months old with 4 days of track practice sessions.
they were installed per ecs install instructions with the loctite supplied.
wheel was retorqued the week before when it was taken off to check an unrelated rear clunk.
AzNdevil
604
290
Hong Kong
now that i am back from vacation, heres a todo list for myself before i forget
ASAP
- new tires, done.
- alignment, remove 0.1-0.2 rear camber
before next track session
- check lpfp filter to see if its dirty or clogged, if not, time to replace lpfp
- order and replace hpfp
- replace rear brake pads with something upgraded
- replace front studs with new front hubs + bolts
- feed racechrono logger with oil pressure data for logging
eventually
- upgraded fuel lines + external fuel regulator?
- install m drive module + get cluster shiftlights working, i'd love to test this on the track
- additional external radiator? tbc after next track session
- new gauge to show oil pressure + oil temp + coolant temp? i bought the gauge already but major hardware change required.
AzNdevil
604
290
Hong Kong
wow time passes by so fast... its been almost a year since i updated this thread
anyways, i havent done much in the grand scheme of things
lets see
  • still have the ecs studs in front, havent gotten around to buying new studs, however, all the nuts have been replaced since they all rounded off many ugga duggas of new tires and fixing stuff
  • havent replaced lpfp or hpfp, lpfp is getting weak (60ish psi WOT) but my original issue was fuel cuts under half a tank of gas, not much i can do about it unless i get a surge tank
  • havent installed the aux rad yet, that definitely needs to go in after going through the data i logged with racechrono during the track session
  • got some ebc blue stuff rear pads, they work for the time being but they are too weak and not balanced with the front pads i am using (project mu 999), might get some custom pads from china
  • still havent installed the m drive module cause i discovered some issues with the canbus transceiver i used while trying to send stuff to the car
  • still dont have oil pressures fed to racechrono for logging nor the new gauge
  • went to a few track sessions, nothing to write home about except for the car breaking down pretty much everytime before i start the session
  • somehow managed to get a new set of discs warpped out of the box which vibrated the hell out of everything. tried to send it and destroyed a new set of pads in the process
  • my front apex wheels are bent from hitting curbs at the track. got it repaired but after a session and some street driving its bent again.
  • original suspension setup/alignment isnt as expected, couldnt get any traction out of corners as the rear ride height was too high. my rear inner wheel pretty much lifted every exit of the corner. wheel lift with a helical lsd = lsd doesnt do shit, no traction, no lsd.
  • in order to workaround this, i lowered my rear ride height by ~2cm, added a 5mm spacer to both rear wheels. tire does rub on the bumper but only when rear suspension is on the bump stop which i have only managed to reach on the street during testing on a bumpy road throwing the car into corners.
  • i cant really do any mechanical work in my parking lot anymore as they had everyone clear out their parking spaces. i had to throw out my jacks/jackstands/some tools and lots of spare parts as i had no space to store it
  • detuned the car to about 350-400whp to manage heat at the track, its gotten better but still not enough to be able to last two hot laps in 13C weather
future plans
  • get intake air temps and boost from canbus into racechrono, i found a possible way to do it but needs further investigation + reverse engineering which i dont really have time for
  • get oil pressure into racechrono, this is pretty much a new project all by itself which i dont really have time for as well
  • aux rad, i really need this
  • test the new nankang cr-s tires, they were out of stock when i wanted to replace my tires before the last track session
  • still working on suspension/alignment setup
  • considering if i should just go for a new used car....f82 m4 seems to suit what i am doing but new car = new project = many $$s. at least i dont have to fight the impossible task of cooling down the N54 for track use. IAT, coolant and oil temps all go through the roof
heres a video, you can see the coolant and oil temps on the right
fwiw, im not a fast driver by any means. and theres ~2 seconds on the table on this track in the current state of the car when i put together all the laps/optimal split times ive driven that day. driver excuse: 2nd time to the track, 1st time ive only driven 10 laps before tire started leaking badly. brakes werent feeling normal, i got lazy and didnt change the brake fluid after multiple track sessions. i might have overheated and destroyed the pad/disc.
hope this can serve as a reference to anyone looking to build a track car out of a e9x n54 car.
