Austin says he can also do the Anodized finish in other colours too. So I'm going for a nice blue....Ready for preorder now on our website and expected to ship last week of February!
Sure can! On our website just select the "Connectors and Terminals Only" option.I would like to avoid using the adapters. Could you sell me the pins and plugs so that I can chop off the ends of the stock harness and convert to these directly ? ( also including the bracket (obviously) for m18 valve cover![]()
Are you still on track to start shipping stock valve cover kits on 22 Feb? Will the black anodizing add another 2 weeks to the ship time?Sure can! On our website just select the "Connectors and Terminals Only" option.
Thanks for the update. Do you know if the e series N55 app will get updated as well?The N54 app update with support for these has been pushed to their respective app stores![]()
I've permanently banned two individuals from replying to this thread. Carry on.
Awesome. Thanks. Any suggestions on what gaps to run for an e40/100% port meth injection application?NGK-94201
Still on track to begin shipping stock valve cover kits next week! I have some out for anodizing right now that should be back by late next week or early the following week.Are you still on track to start shipping stock valve cover kits on 22 Feb? Will the black anodizing add another 2 weeks to the ship time?
OE plugs can be ran, the boots are spring style and work with rounded and flat terminal plugs.Apologies if I missed the answer above...
Can these be run with OE S55 plugs?
Or are we limited to B58 plugs due to terminal shape.
So no issues with using the NGK 95706 2 step colder plugs with the b58 coils? Is there any benefit to using the b58 plugs vs the 95706 plugs?Still on track to begin shipping stock valve cover kits next week! I have some out for anodizing right now that should be back by late next week or early the following week.
What changes in the app to support these coils? Is it the dwell time that is adjusted in the flash tune when the upgraded coil option is checked?The N54 app update with support for these has been pushed to their respective app stores![]()
Yes its the dwell timeWhat changes in the app to support these coils? Is it the dwell time that is adjusted in the flash tune when the upgraded coil option is checked?
Thanks. Is the dwell time a static number or does it change based on dme request?. Just curious if we end up using a max 3.2ms, 3.0ms, or less dwell time with the b58 plugs to understand if we are getting max power out of the upgraded coils as shown in your test.Yes its the dwell time![]()
Bump. Anyone know when or if the mhd app will be updated for early e series n55 so we can use this mod?Thanks for the update. Do you know if the e series N55 app will get updated as well?
Thanks, is the pinout available anywhere ?Sure can! On our website just select the "Connectors and Terminals Only" option.
The dwell table is not static as higher energy is not needed at idle and will instead reduce spark plug life. To find a good balance we ramp up dwell time above 2500 RPM, PR does the same with their dwell table ramping from 4.5 - 4.8 ms as RPM increases.Thanks. Is the dwell time a static number or does it change based on dme request?. Just curious if we end up using a max 3.2ms, 3.0ms, or less dwell time with the b58 plugs to understand if we are getting max power out of the upgraded coils as shown in your test.
As soon as I release the N55 version for pre-order MHD will start adding it into the N55 app's. I will be releasing the N55 version for pre-order next week.Bump. Anyone know when or if the mhd app will be updated for early e series n55 so we can use this mod?
Super simple connector on the B58 coil side you have Pin 1, 2 and 3 (These are labeled on the connector as well).Thanks, is the pinout available anywhere ?
Yes the B58 coil boots are not long enough for the stock/vtt valve covers and therefor need replaced. The boots come off by pulling and twisting (they're designed to be replaced). The new boots included in our kits are made from silicone and use a spring style contact.Hi can you clarify on what you mean by "This kit comes with new ignition coil boots that are longer than the stock boots. These longer boots are a requirement for cars running stock or VTT valve covers and increases the price of this kit slightly. "
Are we talking about the boots on the b58 coil itself? They need to be replaced? Do you have pictures of that?
Thanks
