Spun Crank Hub 6MT
687
Did the bolt back out though? That bolt was ripped out of the crank šŸ¤·šŸ½ā€. The cranks threads are damaged and so are the bolts. The bolt no longer tightens into the crank
how the fuck does that happen? If the bolt was ripped out there were VERY different forces working. The bolt didn“t simply back out.
687
No seriously. If the bolt was FORCED in an axial direction fucking threads. That was not simply a bolt going loose.
So we're all in consensus to write up a waiver with really fine print if the destroyer ever lays hands on our cars ?
Well the crank capture is essentially useless unless you have a 1 piece pinned hub or a hub like the new vac one but that one is pretty taxed in my opinion
1,045
This was what I was thinking. It makes no sense unless something seized and pulled upwards on the hub. The engine was at 6500+ When this took place
687
I am not an idiot!
Wait wutt ? šŸ¤”
