Spun Crank Hub 6MT
Another reason I doubt it's the hub is because you would be getting intake and exhaust correlation codes not just one.
zomski101
Yeah that's what I thought. I pulled the valve cover and checked timing. With the engine at TDC the camshaft timing tools lined up perfectly. I haven't yet taken off the cam hubs cause I'm waiting for the replacement to arrive but I'm hoping that's the issue. Plus when the car isn't in limp mode I get a tapping noise but when it does go into limp mode, seems like the vanos is turned off and there is no longer any tapping noise at 2.5k rpm.
Still wierd that the CBC has twisted to the right and two of the six bolts were finger loose.
If the cbc has twisted is that the bolt has moved a little and the cbc has done its job.
Did you use a little bit of a very mild thread locker on the bolts to stop them backing out ?
