Found it I was close.
5.5inHG the valve should just seat on the openeing and you should still be able to spin the valve on the seat without too much effort
Most people don't check them, and in most cases it's never an issue. But, it's just like I tell domestic guys - it's like degreeing your cam. You're validating that everything is correct before you seal it up. That way it's one less thing to wonder about when/if there is an issue.
If the OP had a shop install them, I'd put it on them - sure, you want them to be adjusted correctly when you get them, but things happen in shipping, and a shop should do things right, and confirming proper wastegate operation is part of the job.
Tyler, who's making those?Here is a testing plate with a hole for a valve stem.
I never understood why the BMW crowd plays these guessing games when it comes to finding a boost leak. The DSM/Evo community has been pressurizing the intake system for 3 decades and you SEE the boost leak. No guesswork involved. Pressurize the intake and find your boost leak.
Spot onLooking at your latest log, I'd say it almost has to be the wastegates not closing as they should. At 3500 rpms, you're running 85% WGDC after pid and only getting 7.6psi of boost. Granted, I have regular MMPs, not the 1Ks, but at 3500 rpms, my tune has WGDC after pid at 39% and I'm hitting 19psi.
Since you have the smoke machine, you might try smoke testing your vacuum lines to make sure you don't have a leak in that too.
View attachment 13779 Whats with Throttle position ?
Here's one of mine - accel pedal is 99.6, which is WOT. Throttle position is 81 until 4300 rpms when it starts closing to maintain boost target.
I can't remember - do you have to drop the turbo to adjust the wastegate? If you can get a wrench on that nut, you should be able to do it on the car.
