Twisted tune 20psi
Was that on pump gas or ethanol mix? Do you have a 3rd gear log by chance? I know spool is different depending on gear.
Twisted tune 20psi
You have a link of what you're talking about? Thanks!For fog machine i just pushed it against the filter opening and it smoked out of the leak within a few seconds. $30 on amazon.
My car still made 30 psi of boostFYI, a fog machine will spot major leaks that will appear at standard 0psi testing. But if you have a leak that doesn't show up until say...4psi of pressure has been applied to your system then a fog machine is worthless.
Pressurize your intake system. It's the only way to be sure.
Also i did have a fuel variance indicating on jb4. When i pressurized and sprayed soapy water the leak was large enough to just blow soap away and not foamThat's awesome that you had a leak so bad a fog machine found it.
But make no mistake. You can still have leaks and make 30psi easily. Especially on big hybrids or a single. There's a thread out there somewhere that chronicled Terry at BMS making 30psi with a 1/4" port open on his manifold. The turbo was just outflowing the leak (and that leak would have been found by a smoke machine).
This is why almost all factory boosted cars have ditched the MAF and gone to Speed Density or Alpha N (this is what the N54 uses) calculations for fueling. With these calculations you are not as effected by a leak. With a MAF you start going rich really quick even on the smallest leak.
Ooooo its about you and your suggestions, and hypothetical situations that you read about. Gotcha. Just saying this advice is for OP NOT you. As your car is not experiencing the issue that him and i share in common. I went through this issue last week.I wasted a lot of time pressurizing. Trips for parts,assembling. Diy searches etc to pressurize and it didnt work to Pin point this issue. It worked to find port injection gasket leak but not this one, anymore then seeing high wgdc did.thanks again for your forum policing.This open forum isn't about you specifically, and this thread isn't even about you. It's about disseminating the *correct* way of doing things so that people who search for this stuff on Google in the future find the right answers, not half truths and partial fixes.
I'm glad it worked out for you, really I am. But let's not mislead people into thinking this works all the time....or even relatively frequently.
Pressurize your intake system, that's the right way.
Best bet. Hope its a cheap fix and your back on full boost soon.I will do both because it all makes sense! Knowing all the options helps a lot.
I’m worried it is the turbos and the wastegates are not probably adjusted or something.
Did you put a vacuum gauge on them to confirm proper operation before you installed them?
