Looking to hit close to 800whp. What setups am I looking at ?
Payam@BMS
412
265
34
Dual 450
Port injection 750cc injectors
Full e85
No WMI
Good for 800whp and has been done many times over.
twinturbos
291
79
E92 335i MT
How much of a pain would it be to have it good for full E85 and for normal gas at the same time ?
2,198
It is doable from my understanding:
1)
Custom 93 tune, your HPFP should be able to handle all you need. No PI needed most likely. So when you run pump only turn off your PI. DI is better than PI all things considered.
Custom E85 tune, your HPFP can't handle all you need. PI is needed. So when your run full E85 turn back on your PI.
2)
Use an E85 content analyzer and the flex fuel logic and have it interpolate between the 93 map and 100% E85 map on the fly. My understanding is you keep your PI on the entire time.
3)
You could try the Helix or other solutions for remaining DI only. Very few seem to be successful at higher HP and most still have to run E85 blends which in my opinion is rather annoying and makes them not a true fueling solution.
Reactions: twinturbos
