xHP Flashtool: Official Beta Results Thread for 6HP21
Kaliber335i
28
E90 LCI N54
I don't want to celebrate too early, like the first time, but i think you got it.
At 2:18 you can see that the tcc is opening from 1st-2nd shortly but then closing again.
But so far this mapping is the best to drive. Now we are heading towards Stage 3 behaviour :)
The early downshift on braking is a nice feature. I'll test this the next days more extensive.
I also made a Log from this drive.
I'll send it to you via PM.
RayBan
154
155
www.rbttuning.com
New app version V1.1.31 online!
- The fuel pump now stays quite during flash
- Fixed an issue where some cars lost their Paddle shifters after flash
- Added a switch to turn off Pre-Flash Safety Checks (only use in case of problems starting the flash)
Reactions: mmm335
mmm335
22
Gold Coast, Australia
Finally got installed :)
Car feels way more responsive!! will do some vids and logs later on, went straight for Stage 3 Map.
Had some install issues due to my DTM u shaped angel eyes, hence delay.
^ Car information (changed TCU from 07+ running on an 06 gearbox)
^ Install issue due to power safety check which was promptly fixed :)
^ Code reading ability
^ Installed finally. (ran the install and flash with no tender, know my battery is healthy, and ran fine after safety check disabled.) I suggest for backup tender be required, as its quite long.
RayBan
154
155
www.rbttuning.com
I now decided to split up the Stage 3 in 2 maps, for further testing the BRS (Early Downshift in D under braking)
Who likes this feature, pick V1.1, who likes it not, just pick V1.0
trebila
65
21
currently trying stage 3 D mode, it feels good so far.
will try tommorow to drastically raise the reported torque in the flash, to check I hit no torque limiter .
trebila
65
21
stage 3 D-mode is not as smooth as stage 2 one.
the best would be a stage 3 flash with stage 2 D-mode.
Cjdzombie
72
12
2011 335i xDrive M-Sport
I've read that some people have reset their transmission adaptations after doing the Alpina flash. I never did it because I wasn't sure it was necessary when I did the flash. Is this something that should be done after flashing xHP?
trebila
65
21
I may need more adaptions, but I feel stage 3 D-mode definitely not as smooth as first version of stage 2 D-mode.
Kaliber335i
28
E90 LCI N54
Marco is one of my customers, the one with the big ST ;)
and here is his latest log, with my tune, and stage 3 xHP TCU flash:
reported torque (green curve) is stuck at 730ft.lbs, 1000nm, in 3rd, 4th, 5th, and no more torque limiter !!!
Nice! I just flashed Stage 3 v1_2 and still got Tq.Lim 4 with slighty raised Tq output. :\
trebila
65
21
it looks like an issue in the DME flash.
do you get timing corrections on all cylinders ?
Kaliber335i
28
E90 LCI N54
Not at all. But yes, timing is dropping while Tq.Lim 4 is active. But Tq.Lim 4 is induced by the gearbox. That's why non-alpina drivers have problems in gear 5+.
I slighty raised the tq. output (fuel eff. divide, for richer fuel) and the limiter was instant kicking in.
My torque limit tables within the dme flash are maxed out.
Something else is wrong. My car doesn't shift as fast as in all posted facebook/youtube videos.
Apperently my car isn't changing the gearboxmode to "sportmode". That's why my shifts are slower then others.
Stock ecu software also doesn't work.. slow shifts (slow is the wrong term, it's like alpina tcu flash shifts) :(
Here's a picture of my limits.
Load2torque stock...
When i'm leaving fuel eff divide stock, i don't have any tq. lim active.
But that's not the sense. I have 650Nm in logs, but my gearbox is only receiving <500Nm. Idk wtf is going on :D
Car was completely updated around 6 months ago.
Here is a Video of a drive an hour ago.
https://www.youtube.com/watch?v=XO8k-tKwhQQ
trebila
65
21
I had to change many more tables in the flash to report 1000nm (730 ft.lbs).
and there is no more torque limiter in the tcu flash.
Reactions: Marco_v_W
Kaliber335i
28
E90 LCI N54
I just changed tq fuel eff and the output was instant higher. If i would raise load2torque at the same time i could easy go to over 800nm, but im not doing 800nm with my stock turbos. There are not much more tables left to raise the tq output.
But there is still the limit issue.
I even deleted the app, downloaded it again and flashed v1_3 stg3 again.
No improvement...
Kaliber335i
28
E90 LCI N54
Here's a log of the same map with alpina flash and 20nm less tq. output (was another day, so that's tolerance)...
