What brake rotors and pads did you go with?
What Rotors and Pads do you have? (Select Two Options)
  • R1 Concepts Rotors
    Votes: 5 5.2%
  • StopTech / Centric Rotors
    Votes: 25 26.0%
  • OEM Rotors
    Votes: 15 15.6%
  • ECS Rotors
    Votes: 14 14.6%
  • Akibono Pads
    Votes: 17 17.7%
  • Brembo Rotors
    Votes: 4 4.2%
  • Hawks Pads
    Votes: 19 19.8%
  • EBC Pads
    Votes: 8 8.3%
  • Pagid Pads
    Votes: 3 3.1%
  • Bosch Pads
    Votes: 0 0.0%
  • OEM Pads
    Votes: 9 9.4%
  • Z4 35is Rotors
    Votes: 7 7.3%
  • Ferodo Pads
    Votes: 2 2.1%
  • Zimmerman Rotors
    Votes: 17 17.7%
  • CoolCarbon Pads
    Votes: 5 5.2%
  • Meyle Ceramic Pads
    Votes: 2 2.1%
  • Total voters
    96
1,686
Thanks. The Cool Carbon instructions with the pads say to do 70-20 repeatedly at low, medium, and hard braking. I was on the highway and couldn’t slow down to 20mph. Stupid me. Live and learn.
Would you suggest to first remove any glaze on the rotors by lightly sanding them with fine sand paper and clean with Brakleen? Or is this not necessary as long as I rebed as you suggest?
I'm not sure I'm knowledgeable enough to answer your question, I've never sanded rotors, I just rebed and it works. Perhaps I'm not sensitive enough to this. I probably rebed my rotors a couple times a year with all the stop and go traffic.
Here's the biggest thing: If you get your rotors hot and then stop completely, you'll leave residue where the pad stops on the rotor and that will create a shimmy or vibration.
I'd try rebedding, and if that doesnt work, try a little sanding. What also works is using a track pad which will remove all glaze from street compounds.
gmagnus7
174
73
135i N54
Have the ECS two piece front and matching rear with Hawk HPS pads. Brake dust is terrible and stains the wheels pretty bad. Switching to EBC redstuff for street use and will just get a set of track pads if I eventually take it there.
GotPwned
21
2007 BMW 335i
Anybody have experience with Sparta Evolution products? It says on their website that the friction coefficient and the temperature range for their SPP 3.0 is higher than Ferodo DS2500s which for a street/track pad is pretty impressive.
