What brake rotors and pads did you go with?
What Rotors and Pads do you have? (Select Two Options)
  • R1 Concepts Rotors
    Votes: 5 5.2%
  • StopTech / Centric Rotors
    Votes: 25 26.0%
  • OEM Rotors
    Votes: 15 15.6%
  • ECS Rotors
    Votes: 14 14.6%
  • Akibono Pads
    Votes: 17 17.7%
  • Brembo Rotors
    Votes: 4 4.2%
  • Hawks Pads
    Votes: 19 19.8%
  • EBC Pads
    Votes: 8 8.3%
  • Pagid Pads
    Votes: 3 3.1%
  • Bosch Pads
    Votes: 0 0.0%
  • OEM Pads
    Votes: 9 9.4%
  • Z4 35is Rotors
    Votes: 7 7.3%
  • Ferodo Pads
    Votes: 2 2.1%
  • Zimmerman Rotors
    Votes: 17 17.7%
  • CoolCarbon Pads
    Votes: 5 5.2%
  • Meyle Ceramic Pads
    Votes: 2 2.1%
  • Total voters
    96
For those of you who have changed your rotors/pads, what did you choose/recommend? I have some slotted Centric rotors with Hawks pads but have been thinking about picking up a set of those black R1 Concepts rotors with Akibono pads instead.
If you have something not listed here tell me and I'll add it.
ECS light weight rotors, two piece...highly recommended. They are a few lbs. lighter and the handling and acceleration is immediately noticeable after install.
Cool carbons...were not impressed with at all. Using Hawk pads now, and also not impressed.
2010 135i N55 6MT
Pagid RS29, amazing pad but very expensive and quite a bit of dust. Were good for daily driving and didn't glaze up too bad or squeal when DD'ing, very impressive seeing as they are a full on race pad.
Edit: As N54islyfe said, DS2500's are a great pad for aggressive street/ mild track use, a lot cheaper than RS29's too
Was looking at DS2500's until I found Pagid. I believe your pads are RSL29's, the L being their endurance pad. Better modulation and life than the standard race pad.
I will be leaning towards the RSL 1 as it is marginally more expensive than the 29 and only slightly less modulation and disc life.
Hassans
69
15
E90 LCI 335i N54
Oem at the moment, I was thinking about HPS pads and brembo rotors.
Hassans
69
15
E90 LCI 335i N54
I don't really see any dust. I get a car wash every week or too but before the wash I don't see any but if there is dust its very minimal and not eye catching. And for the noise I don't hear a sound.
Nice, I had Brembo blanks and hawk hp+ on my last car. Loved the performance and didn't mind the dust, noise was rare.
I might give your setup a go, need to do more research.
1,630
I'd love to see a chart of rotor, style, weight, and cost. My rear rotors need to be replaced soon and I'd love to replace them with a lightweight rotor to help reduce unsprung weight, i.e., improve handling over the OEM rotors.
Bmac
77
34
Great White North
To save significant weight, I think you would need 2-piece rotors. The only rear 2-piece I'm aware of are RacingBrake and ECS. I think RacingBrake are the lightest, and both are pretty expensive.
JValenzSD
33
17
San Diego, CA
2010 BMW E90 LCI 335i M-Sport
I went with the ECS 2 piece rotors to minimize warp and is lighter than factory and with Hawk's HPS+ pads that bite close to factory pads but withstands fading when getting on the breaks corner after corner.
1,630
Two-piece rotors look ideal for weight savings. But I'm not a big fan of cross-drilling or grooves as they all seem to have (I've heard they are harsher on pads). Any light-weight flat two-piece rotors available that fit 335i, other than the front stock rotors for the BMW Z4 3.5is?
JValenzSD
33
17
San Diego, CA
I haven't had any issues with the pads wearing out sooner. I did my entire brake system around 2014 and it's still has a lot of meat left. It's my daily and I drive 60 miles a day to and from the office. I did however perform proper brake pad bedding procedures to get both surfaces to mate. They were very noisy at first, then after bedding them, it's been quiet since.
I don't know of any blank 2 piece discs, but Girodisc has the slotted 2 piece oem replacement with a curved vane design to help with cooling. I know it's not much but I hope it helps somewhat.
Hokie_335i
51
24
North Carolina
2009 E90 335i 6MT
I had two sets of R1 concepts rotors on my last two BMWs and have nothing but good things to say. Held up great with my last 335 FBO and did great on my ZHP.
Venom77
36
27
Arizona
335I
I have Brembo calipers with Stoptech rotors and Hawk HP+ pads. The bite is strong and consistant with no fade. Ive done track days with 20min sessions at Inde Motorsports Ranch here in AZ with no issues. Although for daily driving there is a tiny bit of squeaking.
Mernardi
2011 135i
Stock 135i Brembos with RB pistons. RBF600 fluid. Custom front brake cooling setup. ECS 2 piece front rotors, ECS drilled/slotted rears. PFC08 pads.
The brakes perform amazing on track, but they are they LOUD. I definitely turn heads when I drive them on the street lol. The dust is terrible, as expected of a race compound.
BreakMyBillfold
82
34
So far I'm running what I got the car with, and they appear to be stock pads. From what I've researched, the Akebono pads are what I will get sometime before I need them.
