VTT/Rebello Sleeved N54 Engine progam
Seaneezy
133
34
e90 LCI 335i
How does the top end look with the ported head alongside the high lift cams?
Oct 24, 2016
1,152
1,202
Scottsdale, AZ
The ZF manual is the standard 6MT, which all of our runs, 1/4 mile times, 1/2 mile traps, etc. have been done with prior to going to the sequential. We won't be doing further testing on the 6MT as it's not necessary -is there something specific you're looking for that you want test results for? 6MT is pretty well understood.
1,630
We like the sleeves... they strengthen the block all the way down, not just at the top, plus no loss of cooling. Strongest would be sleeves and closed deck.
Chris
I’m confused. The sleeves fill the spaces in the stock block around the cylinders where coolant goes. Thus adding sleeves reduces surface area in the block for the coolant. Less surface area = less cooling. How do your sleeves not reduce cooling?
  • Disagree
Reactions: Sshec152
LessIsMore
56
22
09 535i
No, that is what the insert does.Look at the pics.
3,629
Rebello has big history in road racing, where motors just get the shit kicked out of them. There are different kinds of sleeves for different applications. @Jeffman you'd have to talk with Rebello to get into the details. No doubt in my mind, though, their bottom end is going to be the shizzle.
Jhuff87
E90 335xi N54 6MT
Yes, I’m familiar with the ZF manual. I’m just curious how they perform together. Not really interested in 1/4 or 1/2 mile times. I do a fair amount of canyon driving though, so just curious about overall drivability with the built motor and MT. Any nuances or distinctions you encountered during testing that wouldn’t apply to an Auto or sequential trans. I understand you guys are setting records with your builds and I respect that. However, I’m looking for a solid performing, reliable car I can open up in the mountains.. so different goals, I suppose.
Edit: I’m sure your guys are looking for solid performance and reliable cars too. My car is more for personal use than competition. Opposite may be said for your builds. Which is why I brought up different goals. Either way, I plan to own one of these motors once available. Just want to know what to expect.
1,152
1,202
Scottsdale, AZ
The built motor and the 6MT? They work exactly the same together as a stock motor and a 6MT. Drivability is not impacted in any meaningful metric. It's a durable, fun, but slow to shift unit that can handle a ton of power and a lot of abuse. Just make sure you choose a clutch that can handle what you want to put through it -we used the spec twin disk, Tony liked that a lot and said the drivability was excellent vs. the Spec Stage 3+, which he welded on aggressive launching.
Jhuff87
E90 335xi N54 6MT
Thanks Chris! Well, I’ve been putting my money away for a little while now that I know there’s a viable option out there. Can’t wait to get my hands on one.
The Convert
1,487
1,053
How did you guys get the sequential working electronically? Did you have to go standalone?
Vdkk
34
24
335 e92
@Chris@VargasTurboTech
Can you PM me some info on darton/rebello sleeves? I currently am ready to have my block sleeved. Machine shop ready. However it's impossible to find info on what is available. I've been looking for existing sleeves for a couple weeks now.
