Thanks your the man, i hadnt had luck finding correct dimensions.Also, google "sae fuel fitting" and you'll see what you're looking for. Lots of options. I think I have the Fragola ones.
If you're talking about this style fitting, pretty much everyone that makes push lock sae fittings offers them.Does FuelIT sell their cam lock fittings separately? Those are badass.
$125 for 2 fittings . Pretty high tax!Does FuelIT sell their cam lock fittings separately? Those are badass.
Cripes, you're running Italian fuel system parts?!!!Lots of options. I think I have the Fragola ones.
Those are pretty nifty. I've not seen another sae fitting like that. Proprietary maybe?No these are the Russell screw on fittings and they are a pain in the ass to install on the hard line. The only thing I could find that shows the cam locks is this you tube link
I suspect my PCV configuration if very common in the marketplace, so asking here as it should benefit others. I'm running the BMS OCC setup (believe that's high side?), and currently have an RB PCV valve. I'd like to externalize the low side and run it through a catch can. From what I have read, that is where much of the intake gunk originates. I believe the BMS OCC has retained the flapper ... anyway looking for suggestions.
Nice thanks ... I saw that once upon a time but couldn't find it ... will read.
Awesome. I still need to get a high-side, flapper-retained catch can and I have the RB external instead of VTT setup but I'm sure they're close enough to not have major differences so it's good to see vacuum remains pretty proper. Hopefully someone checks it with the oil cap breather soon because dual cc + filter cap is what I'm hoping to ultimately end up with.For those that were concerned with crankcase vacuum. I installed my kit over the weekend. Dual catch can, external pcv, plugged head ports. Got -6.4mbar. Should be noted that I have my idle rpm raised to 100 rpms over stock. This is with a/c on. Fully warmed up. With 130k miles. Oh and e60 if that matters at all.
I know it's off-topic, but that @PRECISION RACEWORKS coil set up looks so damn nice when installed. I was already sold on it when they announced it, but now that they have the quick connections and offer coils a LA carte I really can't see any downside. I almost wish I had an excuse to NEED them right away lol.
