External PCV too much vacuum?
Stevo585
29
9
Has anyone tried these pcv valves from radium?
Good time to update!
I actually am using the radium PCV i ditched the 2jz pcv. I found out even running 6an the lines were too big and I was still sucking oil into my intake.
(Head ports are plugged)
Current set up:
Low side: radium 10orb to 6an PCV to a 90 6an to npt adapter with a 1/4 npt push lock fitting with 1/4 air hose —> in catch can with 6an npt adapter with another npt push lock —> out catch can 6an 90 adapter with push lock into the 6 an with a push lock on my intake manifold.
High side: running oem flapper with a filter VTA
I’ll probably end up using the port on the head to use the VTT vac relief valve for a cleaner looking set up, but for now this works!
Let me know if you want me to add some pictures.
BEAT_ITN54
34
I think most people go with 8AN or larger lines which are too big (in my opinion) for the system. I recently did my install using Radium cans, VTT VC fitting, VTT mini check ,6AN hoses on the low side and 10AN on the high side with the OEM flapper valve. With the engine idling and the dipstick from the low side can removed there is a very strong vacuum (in the can) which suggests that the vacuum pull is more than enough to evacuate the crankcase during low load conditions. To date I have not gotten a single code nor drop of oil in the system.
Ya most people go over kill and then have problems that they chase or revert back to stock. Vacuum source line should only be around 5/16 I'd.
Reactions: Smokeuuu
Smokeuuu
Current set up:
@Stevo585 Yeah pictures would be great
billj457
28
19
I've previously come to the same conclusion, the VTT low side -8 AN is way too big and pulls too much vacuum, so much that you could hear the whistling as the air was getting sucked past the seals! I had to revert back to the OEM low side while I figured out my next steps. The Radium PCV seems to be a better approach vs a check valve b/w the catch can and TB, I also ordered one and will be revisiting my low side, this time with plugged head ports, 5/16" hoses, and the Radium PCV.
Reactions: Smokeuuu
billj457
28
19
Just to circle back, the Radium PCV is a really nice piece. After plugging my head ports, I reinstalled my low-side OCC. After getting my VTT vacuum relief valve adjusted, all is great. All was not great, lol. My final setup:
Low Side
VTT PCV Delete -> 8AN to 5/16" adapter -> 5/16" hose -> 5/16" to 8AN adapter -> VTT OCC -> Radium PCV (6AN) -> Test Port* -> Ball Valve* -> 6AN to 5/16" 45* adapter -> 5/16" hose -> BMS VTT TB fitting
High Side
OEM Flapper -> 10AN hose -> VTT OCC -> 10AN hose -> Rear Inlet heater fitting
Reactions: Smokeuuu
billj457
28
19
I was still getting random 2D2E errors and tracked it down to my low side PCV setup. After some refactoring, I'm very happy with it now! My setup no longer needs to use a vacuum relief valve, instead I'm using a ball valve between my BMS TB adapter (I had a feeling the VTT one was leaking) and the Radium PCV. I also added a test port on the PCV side of the ball valve to use with a gauge to dial in ~2 in Hg. So far no 2D2E, and also no whistling seals.
Indy135i
11
Im about the pull the trigger on a radium pcv to match to my new radium cans. What check valve did you go with? I assume by ball valve you mean check valve.
Edit, nvm I see what you mean now. You’re using a ball valve to control vacuum flow to the pcv. Think I’ll follow suit and run similar right at the TB fitting. This looks like a nice and compact option for the task.
billj457
28
19
Exactly, I have mine right before the PCV but anywhere between the TB and PCV would work. I went with an Earl's Ultrapro model and although it was more than I wanted to spend, it's really nice and compact plus it allows you to dial in the exact amount of vacuum without any hassle.
Indy135i
11
Nice, that’s a really nice piece but the cost is indeed high and adds two more AN fittings to the run. I think I’ll go with the flow control valve from granger since I already have to adapt from NPT to AN. I’ll just plug the valve right into the TB then come off of the valve with NPT->AN
Reactions: billj457
Indy135i
11
Just stumbled upon what I think will be an even cleaner option for restricting the 6an lines.
seb.apprenti
286
139
reunion island
www.instagram.com
335 i e92
I have a question that may seem stupid...but technically can we completely remove the n54 pcv system? plug the head ports. remove the low side valve remove the high side valve connect a pipe from the high side system to an oil catch can. what problem will happen apart from maybe pollution? other brands do it..vw for example
florida2002m3
12
The low side needs to apply a vacuum to the crankcase (for multiple reasons) to remove positive pressure caused by blowby. This is why even when people "delete" their OEM system, they still run a line from the vacuum of the intake manifold to the valve cover (crankcase). Valves and oil catch cans are normally invited to the party too.
The high side needs to be able to release blowby pressure when under boost (since the low side is no longer a vacuum). When not under boost.....It also needs to allow some air to flow back into the valve cover to stop the low side's vacuum from applying too much vacuum. When people "delete" the high side flapper, they need to find a way to vent CC pressure under boost, and allow air into VC when not in boost (when in vacuum). This party normally has a check valve and a pressure relief valve.... but there are other configurations that fit the needs of the system.
Reactions: seb.apprenti
