VTT New Product Release Overview!
The Convert
1,486
1,040
For those that were concerned with crankcase vacuum. I installed my kit over the weekend. Dual catch can, external pcv, plugged head ports. Got -6.4mbar. Should be noted that I have my idle rpm raised to 100 rpms over stock. This is with a/c on. Fully warmed up. With 130k miles. Oh and e60 if that matters at all.
Where are do you have your gauge connected to?
Wouldn't crankcase vacuum reading be a nice addition to logging ...
Tuppidsay
116
63
Seattle, WA
2008 535i
I wouldn't think it would be something that should be actively logged but not horrible to check once In awhile. If I get time I might extend the hose to my manometer and check it during a pull.
I'm not so sure. In discussions about PCV system modifications, there is a lack of clarity (no one size fits all) because of the varying state of the vacuum system, in part due to whatever power configurations people are running (i.e.; we don't follow BMW factory recommended crankcase pressures for a 300hp motor), et cetera. Coupled with the fact that the vacuum varies on how the motors are operating. I think some individual data on crankcase vacuum might add clarity. Imagine if it were there for "free" in MHD. I doubt most people have any idea what vacuum numbers their motors are pulling across their operation; yet this is ascribed to all kinds of issues with these motors. Just thinking out loud, but that's why I said it ...
The Convert
1,486
1,040
I just swap my gauge line over to the BMW oil cap tool before doing some pulls if I want to see what my crankcase pressures/vacuum are doing. Would be nice to see it whenever and charted on logs as well though. I'd also love to have individual cylinder egt, maf, etc. Would really help to let you know what's going on with your motor at any given point.
If there was a sensor already on the engine to measure it, sure why not. But there isn't so you'd be looking at some kind of aftermarket solution.
Hence my original comment, "wouldn't it be nice ..."
Panzerfaust
635
438
Chicago
E92 335i
Ordered a breather the other day and received it quicker than I expected which was nice, but I just wanted to say the quality of this thing is excellent. It's obviously a relatively simple piece but it has some nice heft to it, feels extremely solid, and even the filter itself looks and feels like good quality. Probably the best $100 I've spent on the car, and coupled with my external PCV setup I think I might just skip the BMS style OCC for now.
Chris, have you guys tried fitting it with the ring from the original oil cap still on? I know I'm probably in the minority for this website by still using the engine cover but I think it'd look a bit cleaner and hopefully stop the tiny bit of wiggle it has when installed. I didn't have time to try it with the base in place because I put it on at like 10pm but I'm gonna try it
NoGuru
1,213
Just North of Detroit
BMW 335is
I am curious as well as I noticed just a tiny bit of play.
Panzerfaust
635
438
Chicago
E92 335i
FWIW I don't think it's actually an issue at all considering the factory oil caps also have play + with the engine running it should seal it under vacuum, I'm just anal and if I can make it not wiggle I will lol.
