Upgraded T04 turbos for less $ than stock! Wtf? Link inside
Jern54
306
Netherlands
E91 N54 335i
I’m running these (17T) as well for 3 days now. Tune is from Ken and pushing 20 psi (E30 mix) on the base map. Tried E50 as well but without succes, rail pressure drops to 800psi wich results in a cyl #6 misfire.
Spool is great till redline without any lag and or rattle.
To be sure I’ve checked the balance prior to install.
And actually they were pretty bad according to the balancer. They have made 3 runs and a lot of adjustments to get to the final results.
See attachment for the results
Log:
https://datazap.me/u/jer335/first-3rd-gear-logs-hybrids-30-ethanol?log=0&data=3-4-22
Mods:
BMS 2” inlets
PSP aluminium outlets
Stage 2 LPFP
DCI
5” stepped IC
Motiv flex fuel kit
17T Chinesiums
Wagner Downpipes
Etc..
Reactions: b4llistic
Threetirtyfive
135
68
Guys they're here the 19T china turbos
#Aliexpress £991.46 | Billet TD04-19T Upgraded Twin Turbos For BMW E90 E92 E93 335XI 535i N54B30 3.0L RHD MAX POWER 750-800HP
for when you need even more power :) released today. (Ispeedytech) with other clones no doubt to follow. Ask for lhd or rhd.
Reactions: typedRew
Threetirtyfive
135
68
Yes I'm using them no I didn't get them balanced. Still fine. Passed even RB turbos challenge; 2 years 20,000 miles.
135bmw09
are you running these or similar? was going to get these until you just posted about those 19T!
i found those 19T on a website selling for 2.3k and look the same.
Reactions: Threetirtyfive
b4llistic
119
90
BMW N54
Reactions: typedRew
b4llistic
119
90
BMW N54
Reactions: typedRew
typedRew
412
221
2009 335i xDrive
add another one for ordered ebay 19T club, got shipping notification yesterday evening.
hoping they took everything good and continued while everything bad they fixed with this iteration. we will see, stoked and nervous to find out
id love to get in that whatsapp group if possible @b4llistic
Reactions: island road
namsu2430
72
40
Oops...
Under investigation..
Front turbo, aft turbo is bone dry
Did you contact the garage who installed it and left the gasket sitting outside?
It does look like the oil feed line gasket is either missing or it's not tight enough, are you getting any smoke out the exhaust?
island road
195
144
535xiT 2010 M Sport
Is that a exhaust manifold gasket just chilling there not in its rightful place? If a shop did this install I would re-check everything.
Jern54
306
Netherlands
E91 N54 335i
I’ve contacted the garage and they said that the mechanic most likely lost this gasket and took another one for installation. If one of the ports didn’t had a gasket you would clearly hear and smell it, which sounds plausible.
On the other hand it would be quite strange that this gasket would balance on the core all the time.
Tomorrow the car will go on the lift for inspection, I’ve got a borescope to check the oil feed line.
Until now I haven’t noticed smoke out of the tail pipes during decel or WOT.
