Precision Raceworks Ignition System Kit!
08_335i
371
215
2008 ST 335i
What is the recommended gaps to run with this system? and does that change per fuel type\plug type on this system?
PRECISION RACEWORKS
Nov 11, 2016
145
282
HOUSTON TX
www.precisionraceworks.com
The ignition system doesn't determine your gap size it is just one of the factors. On a stock motor you can gap to about whatever you want .035 would be fine, but as you increase boost the gap needed will decrease. For instance on 45psi a .022 gap might be required. So there is no "set recommended gap" it will all be based off your specific needs. How much boost are you running and what fuel?
08_335i
371
215
2008 ST 335i
This at least gives us a starting point per the system compared to our horribly small gap even on low boost applications. I run pump with port meth on about 23psi. When I get access to E85 I run about a 35% mix with the methanol still running, and run from 26-30+psi depending how froggy I'm feeling.
PRECISION RACEWORKS
Nov 11, 2016
145
282
HOUSTON TX
26-30psi I would be conservative and start around a .026 - .028 gap and adjust as needed (if needed)
PRECISION RACEWORKS
Nov 11, 2016
145
282
HOUSTON TX
add me to the group buy list?
Email us [email protected] and ask to be put on the notification list, there is no group buy for this product but we are keeping track of everyone trying to get a shot at the first batch coming in and will be sending out an email to everyone as soon as the first shipment comes in. Should be before the end of the month.
PRECISION RACEWORKS
Nov 11, 2016
145
282
HOUSTON TX
Had a few people send pictures today thought I would share, these are the Beta sets that we had sent out. Production is going great on everything parts are coming in, looking on track to start shipping in about 10 days! Included the pic with the cover on for the guys wondering about the cover fitment and concern during inspection.
PRECISION RACEWORKS
Nov 11, 2016
145
282
HOUSTON TX
Might as well post a full install pic that was sent to us by Jake at Motiv, he is one of the beta testers running a beta set here the production coils and mount are slightly different but this gives you an idea how clean and factory the install can look! And keep in mind the engine cover still fits if you want as well!
