Precision Raceworks Ignition System Kit!
PRECISION RACEWORKS
Nov 11, 2016
145
282
HOUSTON TX
www.precisionraceworks.com
Ignition System is released, click on image to order!
The Convert
1,487
1,054
This kit looks awesome! What exactly are you doing with the wire loom that typically bolts down where the new coil bracket bolts? Does it just bolt back down over top of your bracket?
antiochasylum
65
30
Doug, any feedback on idle, drive responce, timing reduction while boosting, etc? What gap\plug choice did you make?
Idle was immediately improved. Overall driveability improved. I'm running the 95770 at .26 gap on 20psi. Pump gas. Have yet to have a misfire. Awesome upgrade.
Reactions: 08_335i
08_335i
371
215
2008 ST 335i
After seeing all the feedback, once I can put these in the budget I'll definitely be getting a set.
Cheezy
611
225
Toledo Ohio
So I just changed all of my plugs and gapped them to .020. Literally like 100miles ago. Now I'm saying screw it and i want to order this kit. When I install it, would I need to buy new plugs and widen the gap or just leave them and let it work it's magic? I'd rather not spend the extra $80 on top of $530.
