What is the recommended gaps to run with this system? and does that change per fuel type\plug type on this system?
This at least gives us a starting point per the system compared to our horribly small gap even on low boost applications. I run pump with port meth on about 23psi. When I get access to E85 I run about a 35% mix with the methanol still running, and run from 26-30+psi depending how froggy I'm feeling.The ignition system doesn't determine your gap size it is just one of the factors. On a stock motor you can gap to about whatever you want .035 would be fine, but as you increase boost the gap needed will decrease. For instance on 45psi a .022 gap might be required. So there is no "set recommended gap" it will all be based off your specific needs. How much boost are you running and what fuel?
Sounds good, I look forward to running your system. Thanks for the speedy replies!26-30psi I would be conservative and start around a .026 - .028 gap and adjust as needed (if needed)
Can't wait for these to be released![]()
add me to the group buy list?
The pricing is out: 479Will be more interested on how the competitive pricing will come with this
