Did a few sessions testing pump fuel.
Its pretty laggy as you would expect with a 76mm journal bearing.
Boost has been under target by 2-3psi on lower maps and just gets bigger on higher maps.
It wasnt really exposed on the 6266 but the wastegate pipe must have a leak or im down on compression.
I tested map 1 -5.
Boost builds slowly and inconsistently.
Sometimes 12psi at 5000rpm sometimes 20psi at 5000rpm. Even back to back it changes.
Even on map 5 targeting 26psi it only hits 22psi. The target is way higher than actual boost. With the 6266 is was near perfect on target on map 2 and 3 with simple changes.
Started trying map 6 with reasonable targets for the turbo, did 2 runs and popped an O2 sensor. So I limped it home.
The 7675 is much laggier and the ff isnt doing anything so Ill have to ask for help off Terrys crew.
I did a smoke test of the turbo to intake, no leaks.
I need to check wastegate plumbing as I think theres a leak I can hear. Exhaust doesnt sound as crisp and punchy as usual.
Photos of turbo.
Heres a transbrake test. Map 2 17psi.
Ive had a few runs at 22psi and it rips a fair bit harder. Ill get a video soon.
