OEM-level 8HP swaps in E-series cars
MR-KRAKA
85
"unfortunately n63 flex plate has 9 bolt and n54 has an 8 bolt crank. There is not really an easy way to adapt this unless you make a special flywheel, doable but a lot more expensive" from DomiWorks
I guess I'll search for an N57 8hp70/75 from a seller across the pond
What if you were to grind the rivets off the torque converter and mate/weld the 6hp plate to it? Of course only if they line up correctly. I count 12 rivets on my old 6hp21x I have laying here. If you were to use an adapter I believe you will be needing to shorten your driveshaft as well. On my xi it is a tight fit…
TheFixer
551
396
Tennessee
2008 535i
if you do it I’ll go buy another 5 series and do it to.
If an 8hp falls into my lap I will. I know a few places I can get one cheap.
Crazy though. Three years ago I was wondering about swapping an 8hp in. Hardly anything about it then.
Only conundrum I have is I refreshed my 6hp almost two years ago. Rebuilt the valve body. New mechatronics. New seals. Running xhp on it. The difference was night and day afterwards.
But an 8hp in it..... man it will be even better.
Ugh!
taylorw2421
2009 ST BMW 335i Xdrive
Im looking into doing this and want to make sure I have all the needed parts on the shelf ready to go.
2009 BMW 335i Xdrive
Acquired a 8HP45 from a 2011 BMW 535i Xrive
Shifter from the same vehicle
will be purchasing the cantcu
connectors
cooler fitting adapters
shifter adapter
connector kit
What else will I need to find or purchase to make this as seamless and easy as possible?
MR-KRAKA
85
Acquired a 8HP45 from a 2011 BMW 550i Xrive
connectors
shifter adapter
connector kit
Ideally you would find an 8HP45 from a N55 powered xDrive vehicle so it bolts right up to the N54. You are going to have a tough time making that bolt patter/torque converter work for you. I don’t think there is any room to be adding adapter plates without going to a custom driveshaft for xDrive cars. I highly recommend selling the one you aquired and finding one of the many available from an N55. You will also need to get the EGS security reset on the donor trans so figure out the method you will be using on that front. Other than that you should be good with the rest.
Reactions: Svmp
taylorw2421
My apologies it is from a 2011 535xi, n55 powered. I will correct my original post
Reactions: Svmp
Svmp
62
71
M50 DCT & M57 DCT
Nowadays this can actually be done through CANTCU without any extra hardware/software, just a remote flashing session after everything is installed and wired up. :cool:
135boost
250
Finland
135is
I'm just building a zf6hp28 swap to mine because after all issues regarding misfires and things got my car run properly and first tests, first full pull i broke my e clutch shaft. That was with only 27psi and shifts at only 7krpm.
Got on dragy some 4.6s 100-200kph, assume it will run 4.0-4.3s on full boost.
Some 8hp75 could be a choise too instead of this 6hp28
Svmp
62
71
M50 DCT & M57 DCT
Yea, surely a lot of power there, very nice! :sunglasses:
A 8HP70/75/90 would be a good alternative for the 6HP. The 70 takes around 1100Nm (800ft) of torque in stock form, and the others some more. With enough abuse, anything will break though. :grinning:
135boost
250
Finland
135is
Some weldings and machining works
Reactions: wheela and Torgus
MR-KRAKA
85
You’ve been busy I see. Looking forward to the next update 👍
Wow if you weren’t so invested in the 28 I would say go 8HP70 but I can understand why you wouldn’t want to now seeing those pictures. So you converted the 6HP28 to xDrive by welding the tail/output shaft of the 6HP19/21 housing if I’m looking at that right? Your dedication to this project is impressive and so are those times on “low boost” I’m sure it will be all worth it once it’s all bulletproofed. And all in a xDrive converted 135 no less 👏
135boost
250
Finland
135is
I had to swap front end too because diesels different bellhousing but now it's done
There is only few things to mod to get 6hp28 fit even as xdrive.
This test is so cheap, 28 trans for free, 21xdrive few hundred euros, maybe 20h labour by me and wear parts to trans. If this blow up, then it's 8hp time. Those 19-21 are native 400nm trans with added clutchplates to raise torque rating to 600, 28 is native 700nm trans with much beefier internals, maybe 30%, only consern at the moment is that e clutch shaft what is maybe only 15-20% more torque rated.
Maybe this was answered already, but how do the extra two gears come into the picture?
Continuing to hit the paddles, does what?
MR-KRAKA
85
I’m not sure specifically what you’re asking. As far as Kombi goes it works as if oem in D,S,M1-8. For the DME side it’s requesting or repeating the shift from 5-6 for the additional two gears IIRC. On the TCU side as far as it knows it’s still humming along with the F series it came from. There’s some coding involved in initial setup to make everything play nice then the Cantcu handles the communication between the 8HP TCU and the Car. Ken will be able to to get you a cleaner answer for sure.
Reactions: Svmp and 135boost
zyj98yj
E9X does not have ECO Pro/Comfort/Sport/Sport+button,how to selection Drive Mode ?
MR-KRAKA
85
In the software you setup your default setting and one other to use with the DTC button single or long press. I assume most would be set up as mine is default Comfort and Sport+
Reactions: Svmp
zyj98yj
thanks,When using the DTC button to select the driving mode, does the DTC function turn on and off at the same time?
MR-KRAKA
85
Yes, so if you want DTC fully on for whatever reason you will need to set your default mode to the aggressiveness you want there. I’m sure many people just run Sport+ all the time too.
Reactions: Svmp
