OEM-level 8HP swaps in E-series cars
V8bait
505
785
Texas
Doing a swap in a 2008 335xi (6HP21X) using a 8HP45X from a 2015 328xi. The bellhousing had one bolt hole that had to be drilled out and matched up otherwise. Using a N55 torque converter and old N54 flexplate.
Issue I ran into is that the old 6HP21 is around 25 1/4" long, the 8HP45 is 26 1/4" long. Anybody ever see this before? From my research, all of the 8HP45 are 670mm so right around what I'm seeing at just over 26" long, and as far as I can tell the 6HP21 never changed for LCI.
That extra inch makes the mount fail to line up and the driveshafts not fit.
Edit- from measuring multiple transmissions and some help from Josh from Guru Autowerks, it turns out the N55 8HP45X is shorter than the N20 version by almost exactly one inch. Everything else is identical, except for one bellhousing bolt hole that is provisioned but not drilled. Could make it work but not worth it, use a N55 trans. Thanks BMW.
EJLew3221
Today was first runs with this billet internal 8hp70 turbolamik 2.0 3500 stall converter.
there was few issues on this 6hp to 8hp swap, struggled with them some extra 8-10 hour before solved everything out.
Lamiks complete wiring is awesome, work like charm and it`s very good quality, installation few hour.
Lamiks circuit board to reroutine orginal TCU fits like glow, installation with mechatronic few hour.
turbine mod to get 8hp turbine to n54 few hour.
installing gear display and program switch including diagnostic display prox 1 hour
Lamik adaptor fits well, no wuss on that.
then the struggle started, first i had some small issues to get my laptop connect to Lamik, it was about tunerpro comnnections and took me 2 hour to resolve, just testing untion it connected (dummy me)
paddles started to work without gear selector 1x e84 but when selector was connected, it blocked those flaps too.
double and triple checked everything including Lamik TCU cabling, Lamik pin layout, 6hp to 8hp connector, measured everything many times.. until... spoiler alert...
they did a mistake on Lamik homepage in manual--1X e84 wiring picture, it`s totally wrong pin layout, pins numbered fron wrong end of connectoe and ign feed and ground is crossed..
The right one is to be found on HTG similair picture where cables are right
-pin1 green +12v feed
-pin2 empty
-pin3 yellow canL
-pin4 white canH
-pin5 grey +12v ignition
-pin6 brown ground
that took me 8 hour to find out where the fault was that selector don`t wake up..
i did inform Lamik that they fix that on their homepage
I have a N55 will it still work?
135boost
250
Finland
135is
Lenght of my 6hp21x was indeed 15mm longer than my 8hp70x and there was that adaptor plate between trans and engine what
equalize that pretty much.
i found a crack on my block so i pick it up for repair, 8hp trans with 3500 stall trans seems to work as charm ...
900
You found a crack on your block? That sucks, any details you can share?
135boost
250
Finland
135is
Crack is horizontal on the left side of the block in level of bottom end of water jacket and leaking water out from block and in to one of oil drain channels. I will recieve a new block in a week or so with fixed that weak spot of block.
boost135
9
bmw 135i N54
can anyone confirm or deny the claims from the below if the 535i f10 with N55 variant came out with the 8hp70
keystonezzzz
Kenneth reached out to me and took a look at my logs, we narrowed it down to the torque value being reported from the DME. I guess the MSD80 is known for this. I'm still in the process of getting the car dialed in, so every time there's a change in my tune I'd have to compare TCU and DME tq values from the logs and adjust the correction factor. Them TPC Stg2 turbskis are a ripper on the 8hp though, no traction 1st-4th on street tires and only traction issues in 1st-2nd on MT radials :tearsofjoy:.
Did you ever figure out the cause of the tq limiters? and how to remedy them
flguy76
Thought i'd share some info on what's possible nowadays with these transmissions.
I've been driving around for over 6 months now with my 8HP-swapped daily E91 using my own controller (CANTCU), constantly doing R&D and developing further, and now it's pretty much finished regarding E6x/7x/8x/9x integration.
This is the only existing solution that keeps the OEM TCU inside the transmission, making it possible to install without disassembling/soldering etc, doesn't need any tuning, and works silky smooth like OEM. Simply put, it makes the car and the 8HP understand each other.
At the moment there are some beta testers driving around in various cars/engines like N54/M57/N57. Here's a video example of a fast diesel (E92 330xd N57) with an 8HP70X transmission (fully stock trans in the video, it got xHP afterwards).
The nice thing about E-series xdrive-cars is that the transfer case from a manual/6HP fits directly onto a xdrive-model 8HP transmission, so it will also work directly without any extra modifications.
To keep this post more informative than just a crude advert, i want to mention that there also are other solutions available to control the 8HP, in which the OEM TCU is removed and replaced with an aftermarket unit that fully controls the transmission instead, those solutions are TurboLamik and HTG.
This is a great thread with a ton of information, so after 30 minutes I'm convinced to swap my 2010 535xi to an 8hp70x. I'm trying to find a list of what cars or suvs that made it to America with the N55 motor had the 8hp70x. I know diesel engines had them. But I also heard there was an SUV that had an N55 with a 70x? Can someone confirm this? I'm going to source a transmission ASAP.
Boorda
175
99
Royse City, TX
futemire.com
328xi, 335xi M Sport
I dont think any N55's came with the 70(x) or higher. I looked for months until I finally found my 75z in Europe off of an X6 with the N57 diesel engine. All said and done I got it for $3,400 shipped, so you can find good deals out there if you stay persistent. Be careful though, some X5 & X6 have 8HP70 & 75 trans, but the bell housing is different. Those are for the v8 models so be sure it's from an N57. One thing to note is that the starter is on the bottom opposite side from the N55 starter position, so you'll need an adapter plate and a slight modification to the bell housing.
