N54 head work
Milan
413
241
jebi se
your mom
I wish there was some more documentation on this. I haven’t seen any ported head N54 cars that really make any more power than anyone else.
Vargas seemed to believe the cams were one of the best mods, wish there was some data.
rac
341
205
135i ST
Not something you want to do. Torque bends rods, and spinning ain't winning.
A bit of an oversimplification, but still true.
its just a saying, maybe not very global. the point of the story is that the manufacturer optimized airflow for low rpm range because the engine spends most of its time there.
rac
341
205
135i ST
that's why i was wondering about the ramp rates in aftermarket cams. i figured there isnt much being gained in the head from absolute peak lift so the "STA - specific time area" would be maximized through how aggressive the came profile is. and the more aggressive the more acceleration / deceleration of valve weight the springs have to deal with. but clearly the design objective for market success would be "design a stage 1 cam so that the customer doesnt need to spend any more money but still shows improvement". and they would then find the line were stock springs work but still manage to stuff more STA in there.
note i am not debating the merits of anything in particular here the subject is just one of interest. i tried modelling the n54 in EngMod4T years ago and it struck me that the head made more power that it theoretically should, i put the differential down to the affects of DI. that is only helpful for the amount of fuel the injectors can stuff in while the intake valves are open, so the first 300-400whp or so. after that the head s8cks balls. its been too long since i looked at it but i'm guessing the exhaust port size becomes are restriction after doing port work closer to the cylinder, which is why its just better to start with a different head all together.
not to take away what is being done in this thread - i appreciate how the OP arrived in this scenario.
Milan
413
241
jebi se
your mom
From the little info I have. I would be willing to bet that cams provide an increase in area under the curve but the ported head not so much.
I know they flow higher but that’s not directly tied to HP
3,642
Sorry to say I won't have an A-B dyno test, as when this ultimately goes on it will be with other changes (i.e. turbos). I do plan to make a plate and get the head flowed so we know what the CFM is over stock. But I would imagine that kind of info exists elsewhere ... ?
My guy got back to me and so I'll take the head to him next week to assess next steps.
iminhell1
419
207
Just rough goooglin it seems a ported n54 head is good for about 40hp ... not sure where. For the few grand that costs, totally not worth it IMO. 2 More psi and you might get that 40hp.
nyt
335
2010 335xi
My last setup before schrick low lift and headgames ported heads was with a completely different turbo setup, so I can't do apples to apples there :(
foe516
80
15
have you dyno'd your car with the new setup? also curious what the headgames work set you back and did you do cams?
1,663
Yeah and unfortunately there won't be a before/after for mine either since I never dynoed stock and my turbos were SHOT before doing the head anyways.
mikeseli
140
81
2009 BMW 335i
As Omar suggested if the N53 ports where used on the N54 engine from production, at 8-9psi the engine would of produced easily 30-35hp more, so at boost levels near 20psi we are definetly talking 50-60hp just from the head itself.
3,642
According to my EA Pro sim, cams are good for +35bhp, the N53 head conversion alone for +55bhp, and both of them together +100bhp - i.e. more than the sum of each individually.
In my case, wanting a streetable 600whp on Emix - and Omar points out that the 650s tap out lower than the 850s - the idea is to lower the boost not raise the horsepower. My understanding is that one way to look at boost is a measure of engine inefficiency. My hope is, by getting some restriction out of the very restrictive N54 head, running the low-lift Schrick cams (which have a better profile for flow), that we can lower heat and lower boost demand from the 650s turbos. This is about lowering the work the turbos have to do.
This is spitballing on my part.
2,198
Keep stock rev limit - in the worlds of The Old One, "RPM stands for ruins peoples motors."
I would argue the only replacement for displacement, is revs. I would always prefer more displacement in general.
Given we are stuck at basically 3.0L for all intents and purposes and our undersquare design means the n54 will never be a 'real' high reving motor. It is what it is I guess.
Jan 31, 2017
401
829
www.hydraperformance.com
2010 135i 6MT
This whole concept of boost being a measure of restriction is flawed, for as long as the turbo is operating in a reasonably efficient part its operating envelope I find it best to think of boost as a density multiplier on top of whatever the base engine puts out @ a pressure ratio of 1. For instance a bone stock N54 is good for ~220bhp @ 0 boost on the stock tune and with the stock turbos running stock boost. Your typical tuned FBO N54 running HP800s fares a little better, and is good for 240-245 due to the freer-flowing exhaust setup and lower pumping losses. A setup like mine however with cams and N53 head, is good for ~295bhp or thereabouts before any boost is added. To arrive at these numbers you take good ballpark SAE/DIN bhp figures and divide them by whatever density ratio you're running (in itself a factor of boost + intercooler effectiveness). In other words, adding cams to a naturally aspirated N54 will increase bhp/torque, as will porting of the cyl head. Adding boost just amplifies said gains, and said gains mean you need less boost to hit a given power target. Less boost means less heat, lower cyl pressure, and (at this level) greater adiabatic efficiency so its win/win on all fronts.
Jan 31, 2017
401
829
2010 135i 6MT
It'll never be a "real" high revving motor due to the DME's hard limit of 8100rpm. 4G63s and various Hondas are similarly oversquare, and that doesn't prevent them from revving to the moon. The piston speed of an N54 running @ 8100rpm works out to 24.2m/s which, while somewhat high, is far from being a limiting factor.
Reactions: Illsic_Design
Milan
413
241
jebi se
your mom
If Syvecs ever becomes a thing again it would solve a lot of our problems. I know it's expensive but honestly at $5k its a better mod than a port head IMO
I really hate the way we tune this platform. Not being able to alter a VE table is so silly
nyt
335
2010 335xi
no dyno yet, bit over 2k for the work, schrick low lift cams.
