N54 DCT w/M3 Conversion
2,266
813
You mean an MSD81 ?
Mines an 06/09 as well and I have an MSD81 though I don't know if you need that explicitly for the conversion
m_a_itani
23
BMW 335i M3 converted
Yes someone did the conversion of 2006 model and mentioned it that MSD81 needed and DSC needs to be changed as well
Tuningservice.no
60
24
Just got myself a 2010 Z4 35is DCT and i don't care about drivelogic and adjustable launch etc.
Is it possible to have the box shift hard and rapid as a standard setting by only reprogramming the TCU?
Reactions: aus335iguy
NoQuarter
1,662
1,066
Indiana, USA
Z4 35is, 535xi, X5 35i
Looking at doing the wavetrac 2.81 and will take it in to a shop to do the work.
What to expect driving it back on the highway with no other coding or parts swap completed yet?
Stokes
270
177
Houston, TX
2011 BMW 135i
All will be fine as the 2.81 will work with either programming. Non-M or M. That's the route I went in case I wanted to revert back. By the way, I have no intention of ever going back!
LMB335is
301
189
FOB FL
13 335is
Totally off the subject here but I thought you might enjoy this pic. It was in my 335is as an experiment for fit and function and to reverse the process for possible fitment of M3 clusters in Z4's.
LMB335is
301
189
FOB FL
13 335is
Fits and works ? Will wonders ever cease !
Fits perfectly. Exact same dimensions and placement of mounting screw holes, same pinout for connector. After I virginized it and default coded it in my car I just had to try coding a couple things to get the fuel level to register properly. I've been doing a lot of cluster work now as my retirement job so I sold a virgin M3 cluster to a guy, just waiting for him to install it so I can remote in and hopefully get it to work as well in reverse. Other than the E parking brake and fuel tank size everything else is the same.
2,266
813
Good to know if i ever feel like a change. :)
Also @RSL has been digging around in the IKMOS ROM. He’s found some stuff relating to the Mdrive switches. DOnt know if its just where it sits in the ROM or if theres a chance to enable something that isnt otherwise ...
NoQuarter
1,662
1,066
Indiana, USA
So, for my 2011 Z4 35is with DCT
Do I need to be looking for E46 Diff, driveshaft, and output shafts?
derekgates
740
375
NW FL
derekgates.us
2011 335is
Totally off the subject here but I thought you might enjoy this pic. It was in my 335is as an experiment for fit and function and to reverse the process for possible fitment of M3 clusters in Z4's.View attachment 27059
I am SOOOO envious of your low mileage 335is! Mine just rolled over 105k miles.
Awesome work! That cluster looks great. I really want to get a virginized M3 cluster at some point.
RSL
503
I just have a tendency to define things as I think I run across them, but they obviously planned for or left the door open for a 1M DCT. I can't help not to wonder what hardware/coding might be needed to get it active on 335is or Z4is, but seems like it would have to be a lot less work than the M3 swap, maybe for a lot less benefit too, no idea.
Just a few I think are correct:
2,266
813
Am I right in thinking that these are the values for the various Drive settings ? Or are they activation flags for these features? If they're the second one and they aren't active it could explain why mDrive doesn't work with the IKMOS rom in @dyezak and @LMB335is cars.
Or I could be WAY off track ...
Either way @RSL you've found something I wouldn't have been able to do so, thanks!
My ambition is to one day get the drive logic and MDrive into my car but like others the final drive change and therefore the cost in dollar terms as well as drivability are too high. If it could be done through software though....... :)
RSL
503
Just flags to enable/disable functions, but doesn't mean they are the only conditions needed to be met in order for something to work. I really would just like DriveLogic myself, but if there's a way to get everything for 1M without a driveline swap, I'd do the whole thing.
