Ummm....no SirYou don’t blow trannies for fun?
Bouncing of the limiter when doing drifts and burnouts, misfires, basically and bad or interrupted combustion cycle.General question, what causes a spark plug tip to break off and fall into the cylinder, I’ve heard many different things from knock to loose spark plugs.
on how much boost and timing was this done?How much power do you boys think it’s making. That’s full weight plus full tank of gas View attachment 79873
That run was 29 psi and 8*'s of timing. Although since then i have been repeated 5.83's on the same tuneon how much boost and timing was this done?
I just made a dragy run 5.98 on 23PSI and 11 degrees of timing.
Nice run! Sorry if this is a dumb question, but can you tell the head is lifting while its happening, or is that something you see clues of afterwards?View attachment 82349
This is fast on my E91
But now I need to pull the head as it lifted during above pull![]()
Did you have stock head bolts or upgraded headstuds?It misfired during the pull and it spitten some coolant out the reservoir as well. Ive added a coolant pressure sensor now thanks to Reflex. This indicates head lift immediately.
Athena cut ring head gasket witb the M11 vac studs is key. Fuck I need a auto and a bigger turbo thoStock bolts, going full M11 now with inserts
For Sale : well maintained, never abused, never broke anything, etcCars officially up for sale, trying to decide what bmw next. In between a M240i, M340i, or a 540i
If it helps I’m buying a e90 here soon to do a TT LS build. With a TH400It was nice knowing you. You are dead to me.
WTF is the point ????If it helps I’m buying a e90 here soon to do a TT LS build. With a TH400
