MHD update v1.92
Yeah the 1000m events its only registered cars I've seen and no compressed gas tanks in the car are allowed
Rules change for each event but that is what I've seen in the past
2,266
813
Nitrous oxide is allowed on drag racing vehicles in Australia but is illegal for road registered vehicles. Below is a question out of the Transport and Mains Road website in Queensland, Australia.
"I want to fit Nitrous Oxide to my vehicle. Can I do this? If not, can I just simply remove the bottle and leave the lines in and fit the bottle as needed?
The fitting of nitrous oxide injection systems is not permitted under any circumstances. This includes a partial installation or a removable nitrous oxide system fitted to a vehicle."
At least you Queenslanders have good weather....sometimes...
typedRew
412
221
2009 335i xDrive
that’s sickening. sounds like something people should do anyway and tell them to fuck off
GreyNBlueE92
266
93
OH
Do we think that fan set to max and water pump set to 50% is sufficient? I don't want to stress the water pump too much.
I think it'd be awesome if it were a slider with a warning if you go over say 75%. Leave it up to the user with a race only warning or something along those lines.
1,614
2,080
Not going to get that involved for now, it will be on/off. After enabling, it will timeout after 8 min if you forget to turn it off. Turning the car off / on will set it back to normal as well.
Just fan on off max speed to drop iats whilst staging
Replace one of the gauges with a on/off switch
You actually want to keep heat in the engine like water and oil so keep the targets the same as in the settings you set in the flash
Basically fan on or off with a button overriding the fan only
So this can be done without flashing to make it work at the track
This is what I mean and make it like a toggle or what ever will work
Reactions: derekgates
SlowE93
1,831
Just a plane ticket away !
E93
Question, would this be MHD guys only ?
I have jb4 and use MHD to load BEF, and jb4 has similar max cool mode.
Would people like me, be able to use the MHD toggle, or keep using Jb4 ?
SlowE93
1,831
E93
If your using jb4 use the max cool mode
Yeah but im asking if we could still access this toggle they are tryimg to implement.
Seems easier than doing the whole steering wheel dance to get to max cool mode. Also I like what Jake said about having a limiter, so you dont forget to toggle back to normal mode.
I mean hard to not hear fan at full blast, but I like the way this is being thought out.
