Ad: M18 Performance Cast Aluminum Valve Cover
4,345
Am told he has units in stock so I suspect he increased his order in anticipation.
Dec 27, 2016
134
81
2010 e90 335i
Yall using magic to ship? My VC will be here tomorrow haha. M18 killing it!
I will be attending mpact and slipstream this weekend although not racing my car, i plan on doing a little unboxing/install video next week.
twinturbos
291
79
E92 335i MT
So... in the instructions it says the fuel injectors need to be removed.. is this actually a thing ?
FRNTHVY
84
24
Do you have to pull the injectors when swapping to a billet version or to the VTT cast cover?
M18.racing
59
84
E92 335XI & E89 35i z4
I can give you a better answer sometime this week when the rest of my parts come in. I'm doing new injector seals, coils, plugs since everything is coming out.
Or @m18performance can give you the official answer
Cast Aluminum is more brittle than billet extra material is needed for support to the flange. There would be no point with going cast aluminum cover that would crack over time or during shipping.
twinturbos
291
79
E92 335i MT
So did anyone else get around to installing this ? If I were to buy the pcv filter and plug can I run that for a while without breaking stuff until I run a dual catch can setup ? I received mine 2 days ago and will be a while until I get the m18 shaved and then powdercoat it... meanwhile I'll be on the lookout for a dual catch can setup. Is it a problem if I run everything with AN hoses ?
