Lifestyler's 6466 135i
Lifestyler
69
World
135i
Very nice build. I wish i have half as good as your welding skill.....
Very interested in your muffler build. Did you open it up and change up the piping inside also? The piping you replaced looks a lot bigger then stock. What size you used? I guess 3" into the muffler?
All the way 3.5"! At Open valve
Lifestyler
69
World
135i
Doing some mods over Wintertime .
Powdercoating my compressor housing
Building a new headshield
2,198
I like how the heat shield goes up higher than the doc race. Given how much they charge you should consider selling them.
Lifestyler
69
World
135i
I have some spare haead shieds laying around .but dosent fit with other then Mine BC i guess the DP Hits the head Shield.
R.G.
668
328
Henderson, NV
E92 335, F10 M5
Are you planning to run a line to the PCV from the shorty turbo filter?
Reason I ask is to see if you planned on fabbing anything to support the fitting from being sucked in towards the turbo blades. I've been hesitant to just pop a fitting in to the rubber and hoping that doesn't happen.
Lifestyler
69
World
135i
No i dont .
I Run AC Fab pcv and flapper delate fitting Booth to AN10 into my modify OCC and Vta under the car
R.G.
668
328
Henderson, NV
E92 335, F10 M5
Bro
I just noticed the aero on the side skirts while I was checking your fender work
Build is fucking awesome man. Good stuff
Lifestyler
69
World
135i
Refresh diffential with 650i Cover
And Solid rear end with uniball toelink kit
Reactions: R.G.
