Help me pick a turbo kit!
Which turbo kit would you buy
  • Doc Race top mount
    Votes: 20 33.9%
  • 4N Performance bottom mount
    Votes: 3 5.1%
  • Vargas single bottom mount
    Votes: 5 8.5%
  • VI Engineered top mount
    Votes: 4 6.8%
  • ACF top mount
    Votes: 9 15.3%
  • Motiv bottom mount
    Votes: 18 30.5%
  • ADE bottom mount
    Votes: 3 5.1%
  • ACF bottom mount
    Votes: 2 3.4%
  • CES bottom mount
    Votes: 6 10.2%
  • Something that hasn’t been announced yet
    Votes: 6 10.2%
  • Total voters
    59
Payam@BMS
412
265
34
Do not expect an EFR turbo. To be honest, the EFR is a lot of hype even though they make pretty graphs. Great for people who need extreme transient response but basically over 3k rpm and the GTX series is the way to go IMO, it even performs better on the top end. The EFR is a bulky, hunk of a turbo that causes the kit designed around it have compromises.
Only if the fabricator is not competent enough... My kit does not have anything compromised.
4,348
Yes, certainly that statement is not all inclusive. Less room does mean less options, generally speaking. Getting it to fit, and work, is a testament to the amount of effort that went into this ACF kit.
1,672
are you talking about the speedtech kit here? After reading, I'm not terribly interested in the BW EFR, think Garrett is the way to go, but if their N55 kits feature an EFR option, why don't you think they will do the same with the N54?
luchocamp
147
82
f30 335ix / e90 335xi
My Speedtech stg 3 with EFR8374 makes 11.5@122mph at 15psi of boost with Dragy. I am dialing every weekend
Exactly. Efr needs 30+ psi. No good for n54 high compression engine, especially with oem rods and pistons.
Vitan
81
27
Pilsen, Czech Republic
Alpina b3s ST, Cls55 amg
EFRs are good turbos, one of the best in transient response, areas under the curve, but vs gtx they shine in in higher pressure ratios. Between 20-30psi garrett is more efficient.
Btw. Speedtech st. 3 looks great. I want similar manifold for n54 so much...
luchocamp
147
82
Jlcn54
40
14
So EFR are the best for spool, PTE best for top end, Garret best for happy medium? Lol
cloud9blue
255
190
09 E92 335i
I might be wrong, since I am not very familiar with the N55's JB4 datalog. But from speedtech's own dyno, it looks like they are suffering from boost creep with these IWG EFR turbos.
https://www.speedtech.com/bmw-n55
  • Disagree
Reactions: luchocamp
Jan 19, 2017
22
40
Hi guys, we haven't had any boost creep issues. I should probably post an updated log, as the one shown above was an early run (beta bm3 flash testing), and for that run, was limited to the 12psi max JB4 offset over DME_BT, so if you follow the gray line (dme_bt), it is exactly 12psi lower than actual boost, so as the dme target increases, the JB4 lets boost increase also, so it ramped from around 17 to 24 on that run. We've run the EFR's anywhere from stock boost to 30psi. I recently setup an EFR7670 on our 2011 335xi, and had run it on stock flash/boost for a few days... while super boring, it does fine holding down to 5psi if need be. If anyone cares to see a graph of an EFR on stock dme boost, I can sure post up something, but kinda figured anyone looking at getting one of these kits could care less about stock boost.
LoBoost
251
172
2008 135i, 2014 GTR
Well,
Picked a turbo kit! I ordered a VI Engineered top mount kit with a Garret GTX 3584RS turbo with a divided T4, and 1.01 A/R. Jon also was able to customize the downpipe a bit to a 3.5 inch downpipe with single discharge (no "V" split to mate to stock exhaust). I'll be having a custom 3.5 inch exhaust made once I have the kit installed.
I'm going to have all the hot parts coated by Swaintech.
Hopefully with this kit + Syvecs I can make some decent power. I think early 2019 I'll probably looking for a built motor and head!!
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Well,
On a built motor you might be able to get 900whp but its more then enough for stock motor duty. Furthermore you don't have to worry about running that turbo to absolute limit
Reactions: LoBoost
