GS7 program code disassembly project
Also if someone can help dump the ROM, please send me a private message here on the forum( you need to login) or the contact us form at the bottom or send an email to admin at spoolstreet.
2,271
817
Got as far as packing the TCU and got to the post office. Stood in line for 10 minutes before my daughter started crying and I had to leave. I’ll be near there tomorrow though and I’ll have help. I should be successful in sending. :rage:
imad
94
64
BMW e92
Megicmotorsport claims its Tricore TC1766 with an open "custom" design, and offers a bench "boot" mode. Do we have anyone from Magic who can confirm it can do a full dump on the bench?
I'm running DCT with GWS flash, and working on the same issue to allow custom tune (final gear, shiftpoints, etc)
Reactions: aus335iguy
Olza
239
244
BY
BMW 320d
So. I find final gear ratio and wheel factor, Rennstart rpm, stick control and a little bit drive logic. Will try to make some little XDF for tuner pro. Also DTC management.
So first idea is: i will made some 0da file with changed one byte but with old original signature. Who is brave enough to flash it with winkfp?
Im very curious what error appears, if it be DTC error code then very very good, because i can parse checks before in the program. Then you must reprogram to original data via winkfp.
Just say me your datafile version.
imad
94
64
BMW e92
Could you please share those? I have the DKG running GTS in my 335, so I may also try to flash it over.
Olza
239
244
BY
BMW 320d
So you have m3 gws and drivemode button?
There is two latest versions of gts data - 7845773 and 7848442 difference is only some parameter and rennstart rpm from 3500 to 4500.
So ill prepare second one.
I am still double checking, as FLEX indeed lists TC1766 in the available TCU's.
This has been talked about now and then but if it actually works I'm pretty sure we can crowdfund the necessary funds to obtain one of these. That should kick start the reverse engineering process to find an obd exploit and at the same time we can bench flash devices one by one. Perhaps even disabling the security along the way.
2,271
817
From memory they were only 3k or so??
I’d say that’s a wise use of our collective resource... as long as it does what it says on the box
