GS7 program code disassembly project
808AWD325xi
21
11
Moline, IL
2009 335i
I checked out A7848443.0da and see that it's signed with a 1024-bit RSA private key:
Code:
8003FE00:             AF 0D FF 08 87 C7 14 86 C1 94 5A B3  #    /....G..A.Z3
8003FE10: 17 E6 AC 9E E9 DA 0A 7D 2F F2 90 62 69 F5 4D 25  #.f,.iZ.}/r.biuM%
8003FE20: 10 E1 F4 B1 72 29 1D 38 8E D4 96 1C D3 01 B0 20  #.at1r).8.T..S.0
8003FE30: F5 80 0B 70 15 30 93 7B 27 3E A1 C0 85 F3 4D ED  #u..p.0.{'>[email protected]
8003FE40: F1 35 4E C4 64 5E DF FF A0 A6 A7 7F CE BB 02 18  #q5NDd^_. &'.N;..
8003FE50: B5 FF 45 E2 DF 0B E0 4B E6 66 F9 FB 72 90 4B 4F  #5.Eb_.`Kffy{r.KO
8003FE60: 0A 34 0C ED 47 1F 05 4F B3 DC 15 2B 29 26 8F A8  #.4.mG..O3\.+)&.(
8003FE70: 6C 47 14 9F B2 3D 6F 5E 74 84 DA 38 5C 3E 48 09  #lG..2=o^t.Z8\>H.
8003FE80: 8F 94 B9 97                                      #..9.
How did you guys bypass the signature verification?
Code:
You can just skip it. The signature check is actually requested by the tester as part of the write procedure.
I thought you were using WinKFP to flash the TCU with modified 0pa and 0da files. What tool are you using for flashing?
Yes you can use winkfp but you need to patch the files to remove the check.
I'll make an app to do it when i have a spare weekend. Ediabaslib makes it quite easy to build a program.
bernardo774
22
11
Hello!
have someone the PDF with Functional Description for DCT Gen1?
Alec help me to the GWS conversion, all working fine escept one litle issue, some times when i left the gas pedal in 3.000 or 4.000 rpm, i got some delay and rpm oscilation, looks like the clutch desengage to change the next gear but have some 400-500 rpm oscilation. Just happen when i left the gas pedal. With pedal pressed, the gearbox change the gears fine.
This not occurs every time or with WOT.
In D mode and 20-30% pedal, all working fine.
M mode no problens, like the tork puntch, the tires doesnt like
675
I have the same thing happening sometimes. I have only a GTS tune on stock non M hardware.
Reactions: bernardo774
2,267
814
I remember reading somewhere that there’s code in the DCT and linked to DSC that detects throttle closure mid corner and disengages the clutches so the car is not unsettled mid corner
Olza
236
240
BY
BMW 320d
At first sight i can see only SPC (DRM_SHIFT - during shift stage) corrections for clutch torque offset. That table (spc_m_clu_tq_moi_ofs_mult_a_quer) uses Vehicle Speed kmh and Lateral acceleration m_s^2:
Interesting thing is, 335/Z4 have 1.00 factor here (so no modification of torque offset). M3/GTS has it.
DCT Gen2:
Let me see whats going on during Curves. Thats more interesting :smirk:
675
DCT Gen2:
What does this table do?
2,267
814
DCT Gen2:
Yes it was the M3 DSC I was reading about at the time. Dunno if non M has it as well
