DIY E89 Z4 fuel system - DI only LPFP / HPFP
1,663
Also worth mentioning I have a full 450 bucket and a spare 535 pump which I was piecing together when our global shit hit the fan last year. If anyone wants it, basically OBO.
the ekp3 can handle the load of the 295 easily but I agree if the bpm4 is the unit to get if you want to future proof it.
As ekp3's are cheap you can always carry a spare in the boot already coded to the car so if you start to have an issue you can easily change it until one can afford a bmp4.
I don't understand why the keep selling the 450lph pumps for our cars, the difference in price is marginal at best and if
your not using the full potential of the pump or lets say 50% of the flow the 295 draws less amps than a 450 at 80% flow which is about
the same flow rate.
vin number and updating the ekp3 software or what ever needs to be updated through the bmw portal.
Asmo
43
38
What power levels are you targeting? Was the stock e89 fuel pump insufficient? I've seen good results on 93 using the stock pump, in comparison with the 3 series pump which can't keep up..
3,642
600whp with eMix. Stock pump not going to get there. ethanol requires up to 30% more volume, depending on level of mix.
sjobusen
16
how do I loosen the fueline on this? I am ready to open in to the tank and put in my 295 pump..
sjobusen
16
Special wrench. Most of the companies that assemble upgraded buckets sell them. Check out PR.
They're on there pretty stoutly, or at least mine was. Wouldn't want to do it without the tool.
Special wrench for the fuel line? I have the tool to open the lock ring already, but think I need to disconnect the black fueling first?
sjobusen
16
How is the 295 or stock pump working? If I connect + and - wrong, will my pump go reverse then? Or will it not go at all?
Can I test that my pump is working, by connecting a 9V battery?
sjobusen
16
Why do you want to wire the pump incorrectly?
I want to be sure to get it correct :)
Reading your nice instruction.... " Wire the connector so white/brown and red/black." and this does not make sense to me...
On the 295 pump red wire are +. White is -.
From car I got brown/red +. And black -.
Or am I totally wrong here? o_O
Neg89
63
So i put the new pup in,and crank but wont start.If i prime with protools i can hear ir but much more silent than before,whats wrong?
Krampus
68
32
Finland
If you can hear the fuel pump priming just crank the car again. Do you have enough fuel in the tank:sweatsmile:?
Neg89
63
I put aprox 10liters in after swap,do not know which side of tank it entered.Suguest to put in additional 10liters? Would be mess if need to pull the pump out again.
sjobusen
16
My pump worked immediately I tried it in car. Car started directly. About + and - I connected as I wrote before, red from pump to red/brown from car, and white from pump to black from car.
Check again that you do not forget any connector...
Neg89
63
Wait.Doesnt the morelli stated opposite way?
