GS7 program code disassembly project
Jake@MHD
Nov 7, 2016
1,616
2,083
Philly
In the meantime, there’s a way to create BINs from the files in the standard toolset. It’s been attempted unsuccessfully by @bradsm87...
ill post up shortly with some further detail see if any of it helps
I wrote a simple exe to take care of this and spit out a bin file, as I wanted to poke around in IDA when I was bored. It's not the entire picture though, as the 0da + 0pa is still missing the boot loader segment of the code, which is pretty much always necessary to at least SEE when trying to find an exploit. We need a full dump straight from the chip.
@Olza my initial suspicion was the processor is a Infineon TC1766 (the instruction set and various ram sizes matched as well). Do you agree? It was not visually identifiable on the PCB because the chip has no cap on it.
Reactions: houtan
amg6975
278
188
2012 135, 2005 ZHP, 2009 fJCW
I have a valve body as you know and I can send it wherever. I’m home looking after our baby for the next few months... hopefully that means more spare time :sweatsmile:
Can you get to the control board? If so, can you get some good pictures of it, part markings, etc. I can start to see if I can work out a way to get a flash dump. Alternatively you can send it to me and I can start trying to hack it from the hardware side while Olza works on the disassembly. I can't promise it'll actually be successful though, so I think just some pictures would be a great place to start for me.
Reactions: houtan
96017500-5587-4CC9-999D-6FC0F631E95F.jpegFDD499BE-195A-4F6A-9AB0-6EE734A9172B.jpeg9B4FC450-9A1F-4D6F-9F2F-B04BF0F3DB74.jpeg
Reactions: houtan
amg6975
278
188
Oh my. I don't think I've ever seen a fully DCA/additive board like that. That is something.
687
On the middle picture there is a QR Code on the top right side. Normally you can read those with your normal qr code reader. Within that QR Code is all information the customer requires from the supplier. Mostly production date, shift, etc etc etc.. but there is more
I was given these instructions last year by someone but I've never had one in my hands.
2,271
817
Some of these pics may be of the unit I have.
we ran the qr code before and all we got was a number
I measured the input resistance and got varied results. Found out later that one of the surface components was loose
we ran the wrong code before and all we got was a number
Yeah, you sent me this pic, it was the one I wanted you to measure :grinning:
2,271
817
I can’t for the life of me find the resistance measurements I took.
I’ll have to try it again. Lunchtime today I’ll seperate as much of the valvebody from the TCU and I’ll send it
amg6975
278
188
I don't think the resistance of the input terminals will tell you much of anything. The component you're poking with the pen is a capacitor, not a diode. Diodes are the white squares with the bonded wire coming off the top.
Reactions: aus335iguy
azshantris
155
141
2011 135i N55 DCT GTX1000
I just had all but the diff (incoming Monday) delivered for the m3 gts mod and now there might be a breakthrough coming? Dangit 😅
I'm not "super" electronically inclined but if there's anything I can do to help before or after the flash I'm certainly willing! 2011 135i DCT
Also have basic OBD cable and tools on windows and some basic coding skills.
2,271
817
I wouldn’t worry, this could be a while
Reactions: azshantris
Ya never know with this kind of stuff. Could be next year or two or never before anything is truly available (Lets hope not)
