I cannot believe it's been since August that I last posted!! Man, time does move fast, sorry about that.
I have so many updates!
For starters, the car is back together! First start just so happened to fall on Easter morning, truly a resurrection LOL. But lets not get ahead of ourselves. To rebuild the engine, I first needed to clean everything, that was critical for the best seating of the valves and making sure the engine had the best chance for success. Step one was cleaning and then boring the block. Nothing crazy, just a simple 20 second boring making sure to keep my motions consistent and always moving. Once clean, I could start assembly!
Installing the crankshaft, which I have to admit was more stressful than I expected. BMW (as well as many other manufacturers) prints the clearance 'range' on the crankshaft and block. The crank was all 'r' while the crank case was a mix of 'A' and 'B'. I spent maybe a whole month going back and forth on this because I wanted to use upgraded ACR bearings but they basically only come in packs that are one size. I did a LOT of reading, measuring, asking various experts and came to the conclusion that the performance bearings actually are intended to give a little more play which allows for more oil to flow into the area. So I did just that, ACR performance bearings are in and I sent it.
Now for the head rebuild. This was a process, and took a hell of a lot of time to do. Was also quite nerve-racking as I was terrified I was going to shoot a lifter spring into my forehead, thankfully that didn't happen. I did seat the valves twice just because I wanted to make sure I had good seats in there and I braved the cold weather of winter to wash the seat compound off the head via the outside faucet, then I baked it in the oven to dry it out. My kids were very confused. Since I had two heads (the cracked one from the blown engine and the new one) I went through and took the best looking components from both to install into the one good head.
I used a 3D scan tool to scan the head and then 3D printed a "filler" that I used to hold the valves in place while I installed the springs. Most time consuming part.
Next was the pistons and rods. This was fun to do, I enjoyed the process and it was great to see them sitting in the block....even though I dropped one. But I'll give Manley props here, I called their support line, told them what I did and they overnighted me a new piston, for free! Now that is what I call customer support!!!
To Be Continued....
To Be Continued....
