Technical Emtron KV8 Precision 7675
Brule
386
454
335i 2007 6spd manual
Exhaust back pressure fittings.
Brule
386
454
Working on this over the wknd.
Turbo compressor cover cut off and made aluminium pipe straight to intercooler.
Oil feed and oil drain fitted.
Turbo bolted down.
Headlight work to allow air to turbo half way done.
373 gears are in. A
ll rear end is back on including wheels driveshaft its 100% done.
Next up welding bungs in for sensors
Make 4 inch downpipe
Wiring sensors to ecu.
Then PDM install and ecu setup.
