2,267
814
I’m sure that picture can be coded in the KOMBI later. It was part of the initial complaint customers had. The status is likely a symptom of your issue I’d say.
Reactions: azshantris
Stokes
279
183
Houston, TX
2011 BMW 135i
Found the instructions for launch control. So I was doing it right.
Sucukman
26
BMW 335is
can maybe one of the people who got it going summarize what you need and what not and how you can get it all going? there are now 3 or 4 threads and the information is scattered between the lines. you can read 5 days but you can't get any further. my clutch slips all the time, despite re-teaching with ista. The paddels dont work since changing from IKM0S to INA0S beacause it wasnt necessary
. Before I continue to invest money in the 3.15 M3 LSD, can someone tell me whether the clutch slip has anything to do with it?
thank you
3.15 LSD and axials are installed, Clutch still slipping. Will try the M3 CRT Software, and go back again do IKM0S. if it dont Work will Go back to stock and Sell all the M3 Parts before the clutch is killed.
Edit: MDM is not working too
Reactions: Begood69
derekgates
740
375
NW FL
derekgates.us
2011 335is
What is your overall status? You have GWS, diff, axles, driveshaft? You have the coding done?
MDM is not expected to work.
NoQuarter
1,662
1,067
Indiana, USA
Z4 35is, 535xi, X5 35i
I have this retrofit completed on my Z4 35is ( still on stock diff)
I can get the checkered flag, no foot on brake. When I start to hit the gas pedal, It wants to roll forward and I have to stop and hit the brake.
Any thought on this issue?
Sucukman
26
BMW 335is
GWS
EDC/Power button
Drivelogic Button
M3 SZL
M3 Steering with Paddels & MuFu
M3 Combi
M3 DSC MK60
M3 3.15 LSD and Axials
Wiring is Done, Wires to MK60 and to MSD81 are installed.
flashed the M3 GTS Software
flashed the 1er M Software (IKM0S)
Coded the VO for M Drive and M DCT
Coded the M3DSC, Kombi, CIC, MSD81 and GWS
so ive flashed back to INA0s because someone said its not necessary and MDM or Power not work.
My Problem now, Paddels dont work, Clutch is slipping.
Adaptions of DSC, Trans and Clutch resettet Via Ista
No Error Codes
Stokes
279
183
Houston, TX
2011 BMW 135i
Early on mine would do the same. It crawls less now. Maybe took a bit to adjust.
Reactions: NoQuarter
Begood69
234
114
Fayetteville, NC
U do need the IKM0S for all the mparts to work right with M button.
Mine now works.. all is good. .. to relearn dct. I can use ista and it will work.
If u need help. U can reach me here or 9103648118
Sucukman
26
BMW 335is
flashed IKM0S today with MHD Stage 2, looks like slipping is better, but its just 14 psi. will reset all tomorrow and drive 500 km to make all adapted, maybe it work. M Botton work, Power and MDH dont work. Paddels dontwork, i will try to change pins tomorow, i had modifed them to work with LCI Car before, put resistor in. so maybe the M3 GWS and SZL dont like the Resistor.
Ive tried allso to put VO UR91 to see if MDSC will work, but cant code it after that.
Begood69
234
114
Fayetteville, NC
What is UR91 on the VO?
Sucukman
26
BMW 335is
Just looked it up.. UR91 it is LHD Euro 1M coupe.
yes. its 1er M.
will Try to Flash 1er M DSC Zusub. Maybe MDM Power etc. will work
Edit: 1er M DSC Software cant be flashed with winkfp.
Begood69
234
114
Fayetteville, NC
did someone here try it? something diffrent to M3?
What do u mean? The process to flash is the same for m3 or for 1m zb into a dsc90 non module. As long u put a copy of the zb file in the folder develop, u will see it in the expert to flash with winkp.
And yes some done it.
