2,267
813
Need someone with M3 or 1M DSC to validate this
In the CIC there’s a product line or PL setting
@TireDeathRacing found that you could disable DSC completely from the CIC when you changed the pl setting to the Z4 one.
tbe z4 DSC has a sport + traction mode similar to MDM
It COULD activate MDM if we’re lucky
Sucukman
26
BMW 335is
does anyone else have the problem that the sway bar touch the M3 drive shaft sleeve ? i have Whiteline Sway Bars, they are thicker than oem..
Begood69
234
114
Fayetteville, NC
He said to follow them on xhptool on fb. We will see. I know i have 0 issues on m3gts flash. Dynoed at 1100mn so far.
2,267
813
So would anybody be interested in hearing about an F80 DSG gearbox behind an M57 with 3.15 final drive in an E36 chassis no less
@Svmp... welcome !
Reactions: namsu2430
derekgates
740
375
NW FL
derekgates.us
2011 335is
Maybe not ready yet. Hahah freaking flywheel. Booo
Them famous last words
I increased WG to 1.0 bar vs the 0.9 bar i had on. That should get me to 43psi. But i am also getting a new 4 ports MAC see if the MAC is the issue. To be continued...
Sorry you are going through this, just a funny line up of posts. Things break and it sucks ass. I'm trying my best not to push my car too far cause I am lacking skills to fix a problem like yours!
You said you contacted MFactory? Are they gonna help replace, or what is next steps?
Begood69
234
114
Fayetteville, NC
No biggy man it happens.. i am awaiting on them to reply. They forwarded the pics to the engineers. But i noticed a few issues on the fw and told them about it. We will see what comes out of it. I have a way to fix it like easy fast and furious. But i want to see what they reply. If i have to send the fw back or what..?
Btw. I will b in ft walton 6-12 dec if u need anything.
And anyone in tampa around thxgiving week.
derekgates
740
375
NW FL
derekgates.us
2011 335is
Cool! I hope they can work with ya and not have to ship the entire thing back first.
Alright! That's 1.5 hours away (used to work in Ft Walton). Lots of good food and such around there. No clue what is open since COVID as I switched jobs... but would be cool to meet up! I'd love to see that beast of a car.
Keep us posted on what happens! :)
Reactions: Begood69
Begood69
234
114
Fayetteville, NC
Well finally finding some time to fix this. Get it running for a lil .. sell my SSP Spec-r clutches and buy 1400nm + rated basket/clutches. Pm me is interested on the clutches.
Got the car running. Just need to do relearning and finish reinstalling the parts. Then i will run low boost 28 ish unyil i can affort the upgraded setup
Reactions: derekgates
2,267
813
I can’t believe Your car doesn’t get more attention
I think it really needs its own thread ...
cmon man that thing has it ALL and makes a lot of other efforts seem half hearted. What was the last dyno pull again ?
Sucukman
26
BMW 335is
if one wants to do this conversion ..I am selling my M3 parts because of vehicle sales
M3 3.15 LSD
M3 Axials
M3 GWS
M3 LSZ
M3 Odometer
M3 DSC
M3 Driveshaft adapted for DKG or automatic E92
M3 Center Cosole E9x
M3 DSC Center button
M3 Power EDC SPORT button
all necessary plugs
Parts located in EU. PM If intrested
m_a_itani
23
BMW 335i M3 converted
No more $205 replaced by $2MK and $2MD.
Dme (1km0s), CIC, m3 kombi, dct (gts 0042 ) coded.
I am using protools. Tried m3 dsc but when trying to calibrate with m3 szl fails. Also m3 gws does not show in my modules. So not coded yet.
Should i suse ncsexpert? Also m3 dsc is C8F version. And some of the coding is not the same i find online so i assume i should do same ish in the c8f version. If similar option.
The wipers r on all the time for now and the water pump seems to b always running too.
Thx for the help.
Ps: any answer on the m3 speed sensors? Do i have to swap mu sensor to the m3 type? Or do i have to repin them to other places?
Ps2: i did swap my multi button for the m3 with M could that b what szl had issues calibrating. Paddle shifters work.
Hello, how did you sort out the water pump issue?
