Question: Does a normal walbro (if installed with a Hobbs for example) run at 12v ? Does this allow us to bump it up to 13.5v and essentially add another 10gal/hr at our given fuel pressures? Like if someone was at the upper limit of their setup with a 450 for example.
A single 450 Walbro would not require a Hobbs switch. It would run directly off the stock controller...which will intermittently go over peak limit, ever so slightly. I had a single Walbro on the stock controller and it ran fine as long as my tune did not cause the fuel demand to exceed limit... each time it exceeded limit, there would be a slight, "wao wao wao" oscillation when accelerating under certain conditions...like going 60mph then half slam pedal to pass someone.
After installing this upgraded unit...there has never once been any oscillation of any kind under any conditions or loads. Just works flawlessly and STRONG.
Yes I know, I meant if you have a second pump. I guess if you hooked up it to the stock EKP I assume it would be 12V then.
If you have a second pump, then that is considered a stage 3 set up (two pumps) stage 4 set up is 3 pumps. Stage 2 set up is just one upgraded 450 Walbro pump. I have never heard of anyone adding a walbro pump to their stock pump. If you have more than on pump, you necessarily need the upgraded controller for sure.
The fuel it FI-650hp kit uses a stock pump as the first, then a walbro 450 as the second pump and is rated to 650 hp on E85. I guess I'm wondering if this can push the voltages higher since it's not directly off the stock EKP, and get more out of the pumps.
- Get Oem connector
- Get Copper top hat screws
- Profit
Has anyone actually done this with a stage 3 yet? Found some bronze screws that fit but debating just going stage 2 until I get a billet tophat. I know it "should" work but looking for some reassurance.
Wait do people actually get throttle fluctuations because of hobb switches? How does that work? I though just the LPFP fluctuates in logs? I just received my fuel it 650 package with the hobbs switch so now I'm curious. Since my ekp stays only with the stock fuel pump it shouldnt give codes or anything.
Finally got mine installed, just have a single 450 connected atm and was having some stalls at low speeds with no codes besides the ekp3 being overdrawn. Hoping the bpm4 allieviates that.
Is everyone just connecting it directly to the battery? Started hearing about battery drain issues, wondering if people are running a relay/fuse tap instead or it's just cars sitting a while on old batteries.
