In for more feedback. Thinking about ditching all the extra BS and simpilizing my fuel system.
What would you like to know ?
I'm going to follow this to get more reviews than just a couple people before I jump on it.What would you like to know ?
Yikes! That is an accident waiting to happen ;-)Just updating
This is what was happening to my wiring as it wasn't big enough from the kit supplied by fuel it, mind you it was almost three years old but still an accident waiting to happen.
I've seen people post about it before, but i thought they wired it wrong
No, one is a fuel controller(goes in the trunk) and one is an engine management(goes under the hood). You could use them together if you wanted. The adaptronic controls PI injectors but not the fuel pump in the back(afaik).Is this like the Adaptronic unit from VTT with less functionality?
Thanks!No, one is a fuel controller(goes in the trunk) and one is an engine management(goes under the hood). You could use them together if you wanted. The adaptronic controls PI injectors but not the fuel pump in the back(afaik).
Second thatI know I might be asking a little too much but is there any possibility of an android based app ?
Carrying a laptop for logging is a major pita.
For the OEM pump connection option, I assume that means if you're going with say the fuel-it 650hp option (just adding a 450 to the existing LPFP)? For a stage 3 (2x 450s) that option isn't needed?
With the OEM connector option, we provide you with a BMW OEM top hat connector for 1 of your pumps when using the stock tophat. With this option there is no cutting or splicing of your factory wires to get the connection to the primary pump.
I went to your site to order but got super confused. Here is what I have on my car and I need to know exactly what to order:
1. Stage 3 Precision Raceworks LPFP with hobbs switch
This set up is comprised of two 450 pumps connected to the engine via wire into the charge pipe hobbs switch.
I just need to know what to order and what options to choose so I am not missing things or have things left over after install. I am assuming the install will be plug and play with no fuss. Take out old Stage 3 battery wiring to the top hat, and replace with your wiring setup. Hope it comes with instructions.
There are options that could or could not be necessary and not clearly explained. For example, there is an option for "OEM PUMP CONECTOR FOR ONE PUMP" which is confusing.... Do I need this if I have two pumps that are 450 warlbro? And do I need a top hat? I mean, my car already has everything installed from precision raceworks and it would be bizarre to require a top hat purchase.
Thanks for your assistance.
VT
