Good to hear it does what it says it does.
I just drove back from lunch on the highway and did a preliminary test of 20 mph to WOT on stage 3 xHP and the car reacted much better than ever, since I installed stage 3 lpfp and PD Transmission last year. It did not lurch or jerk at all. Only a slight hesitation in shifting time from 3 to 4. There was no 'backwards' sensation, no violent banging noises, only a slight coasting, then launching forward when shifting engaged. So maybe that can be adjusted in the options menu in xHP.
So here is my theory: So long as your car is stock or slightly upgraded to stage 2 lpfp, and you use xHP on stock or PD Transmission, you will not have any abnormal shifting behaviors or throttle oscillations or choking sensation when wot. Once you get to stage 3 lpfp (more than one pump running on the stock ekpm 2 or 3 controller), then you run into throttle choking sensations, fuel fluctuations due to deficient voltage regulation and maintenance. This in turn has a chain reaction throughout the system as the ecu senses these deficiencies and tries to compensate by reducing fuel pump performance, which results in the choking, jerky behavior of the engine rpm and the TCU is going apeshit trying to keep up finding the proper gear/shift moment.
Once you upgrade your ekpm 3 to this PM4 unit with the proper architecture (choose 2 pump setup if you have two pumps, or 3 pump setup if you have 3 pumps), there will be minimal to no more voltage fluctuations that cause the ecu, tcu to go haywire. And if my theory is correct, using the hobbs switch to activate your stage 3 2nd lpfp is going to confuse the shit out of the ECU and there will be the left hand going left and the right hand going right...resulting in very abnormal engine and transmission behavior.
That is my 2¢. - oh, also.... NO MORE FUCKING LPFP Plausibility errors. Thank Zeus!!!
