Great.... I wonder then (obviously we only have a few data points for the front) if all front diff's are welded then. At least that means everyone needs gears possibly? lol
We're trying to develop it for bothSo is this for manual or auto front diff?
@battlehawk stated that his front was bolted, so there are bolted frontsGreat.... I wonder then (obviously we only have a few data points for the front) if all front diff's are welded then. At least that means everyone needs gears possibly? lol
Yes, the 535i's follow the same convention as the 135i/335i. If it's an E6X AT, then the "rear" is 100% bolted
If the front diff that I have is from an AT 535i, then yes, that confirms that the front diff does NOT follow the rear
Ok guys, I just need to confirm a few things as someone mentioned there was a "bolted" version?
1) If we make an LSD only, this actually only requires 10 sets (at the original $999.95 price). We would need a "bolted" oem sample to take measurements from though. I believe someone posted this up earlier in the thread? Of course, this is of no use to those who are "welded" though, unless they wanted to try find a "bolted" front diff from a breakers/scrapyard?
2) If we can get the "bolted" sample (will need both the diff and ring & pinion to verify measurements), I will check to see if the overall dimensions are the same as the "welded" sample that we have here. If it is, then we only need to make the 1 LSD that will work with both fitments.
3) For the "welded", we would still need to make a ring & pinion. For this, we originally required 30 sets, but if we can get 20 sets @ $1500 (inc. LSD), I will foot the bill myself and keep the extra 10 sets as stock
4) Someone also mentioned that the AT and MT are different ratios (I'm talking about the front ratios, not the rear)? If so, that introduces another problem; A new ratio means an entirely new ring & pinion = min. 20 sets
You Read it correctly. We are teaming up with @MFactory in our quest to further solidify the prior neglected X-Drive drivetrain found in our beloved BMW. We have worked with M-Factory in the past on Mazda oriented products and have had amazing results. So we are at it again.
We already have Rear LSD Diffs available so lets seal the deal with a Front LSD. M-Factory has agreed to take on the project of producing their Forged Helical LSD for us in Front Diff Fashion.
PIC For Attention:
We need 30 confirmed buyers for this to happen. No Flakes, only real buyers. We will also need a sample stock Diff which i will take care of and get sent to M-Factory once we have our 30 confirmed buyers.
MSRP is similar to their Rear LSD offerings: $1500
(50% deposit, then 50% when the rest are due to ship)
CONFIRMED BUYERS:
1 Twisted Tuning
2 Travis Harre
3 Ivan Sanchez
4 DrWeedLive
5 Jesse Cameron
6 Alex Peterson
7 Tim Bies
8 Duane Pugh
9 Brennan Wallman
10 Michael Rooney
11 Erik Chik
12 Maniac0908
13 Bsimmi15
14 Btxbimmer
15 The Banshee
16 Mistajay
17 Taron
18 FOXYZ
19 shushikiary
20 Brian Antic
21 scrllock
22 Rstech
23 Shooter26
Copy and paste the list and add your name if you're in 100%, no maybes!!
PIC For Attention:
CONFIRMED BUYERS:
1 Twisted Tuning
2 Travis Harre
3 Ivan Sanchez
4 DrWeedLive
5 Jesse Cameron
6 Alex Peterson
7 Tim Bies
8 Duane Pugh
9 Brennan Wallman
10 Michael Rooney
11 Erik Chik
12 Maniac0908
13 Bsimmi15
14 Btxbimmer
15 The Banshee
16 Mistajay
17 Taron
18 FOXYZ
19 shushikiary
20 Brian Antic
21 scrllock
22 Rstech
23 Shooter26
