Was on wedge till motor blew. Going with Motiv once i get a motor and Pure stage 2 DD.
So far, t
Twisted is doing very well with maps. The latest one has very good throttle response now and consistent smooth engine power.
I have posted, several times, the results. With charts.
It isn't personal experience, it's fact. As in, I dynoed without outlets, then installed them, then dynoed. That's called independent 3rd party objective testing.
Can someone tell me what was the point of this train wreck, I meant, thread?
E85 is not relevant, as these changes changed airflow and nothing else.
Stock turbos.
Fuel supply mods are irrelevant, as these changes changed airflow and nothing else.
All of these questions were answered in the thread(s) FWIW.
There is no point. Just an asshat coming to argue with my report on my car...which is completely different from his car.
So my results cannot be duplicated even when the build is duplicated? Interesting theory.
Remember boys and girls, swapping to GC turbos and gaining power only works on Tony's cars, nobody else sees power increases.
The gains you see with inlets and/or outlets will still be represented without any tuning changes at all, just maybe not quite to the full extent.
The tuning changes between the posted dyno runs for the outlets were negligible. We did one logged 3rd gear run, made a couple quick changes, and dynoed.
The problem here is you're not backing up any of these assertions with data or fact. You simply installed the parts, and tried to "feel" if they made a difference. That doesn't cut it, and thus you cannot even begin to hypothesize that said parts did not make a difference.
