Just want to make a post about this and thank member
@Cheezy for relaying some photos to me during his install. He had some issues getting the front insert to fully insert into the stock mount. After sending me pictures and some PM's given back and for over the last few day, he has helped me figure out what the issue is.
The photo below is his mount and where it stopped.....
If you've taken a look at the published install manual, you know that the mount insert is supposed to seat pretty much flush with the OEM mount as seen below....
I went out and purchased 4 mounts from 3 different places and what i found was that 1 of 4 of these new mounts (OEM part numbers) had some small difference in the stock mount shaft diameter. I think i got lucky to get one that was different without needing to buy more.
3 of the 4 mounts the casting is a straight cast from the start down to the rubber. one of the mounts however started the exact same size, but as it moved down to the rubber portion of the mount. The diameter of the shaft was actually larger by 0.49mm (we'll round up to .5mm) so its tapered. So looks like the same part number has a variance in casting somehow.
This is what myself and
@Cheezy agreed is the reason his front insert did not seat all the way in. I have no idea why this is the case. as the OEM numbers were the same on all 4 of these new mounts. But this is what we found.
So now, how to handle this possible issue? Being that i cannot predict which mount casting you guys may have in the car since they are the same OEM part number. It's virtually impossible for me to know which style you as the customer has in the car. The only way to know is to either measure the mount with a micrometer or do a test install.
These inserts will be able to be squeezed into place by hand. So if the mount stops, you more than likely have the tapered mount and the center/rear of the front mount insert needs to be opened up a bit.
This can easily be done with a dremel by adding a few minutes to the install by using a dremel sanding bit to remove some material evenly around the center bore of the Front mount insert. Again, we are talking .49mm which is about the thickness of a fingernail.
So, in the event of someone having the tapered mount. I will offer them being able to send the insert back and i open it up and send back. Or i can send the sanding bit for the dremel with new orders or current ones i can send in the mail and you guys can do it yourself.
Just trying to figure a best route remedy for this. I would just increase the center bore diameter, but in the event the owner has the straight mount casting. The center bore of the insert would be bigger, and fit looser than i'd like and possibly knock a bit.
Asking for your thoughts?
