Addressing N5x oiling and spun rod bearings (Accusump installed)
Mterkait
26
Kuwait
F30 N55 '13
Sorry for late reply, but here are the last few logs. I didn't even open them.. too late to check them anyway have new bottom end from X5 n55b30B. and car is up and running again but back to very stock form, FBO pure stage 2 and bootmod3 OTS.. i call this stock yes ;p
I was running PI fuel, so i was running only 93octane on top mount single 6266 docrace.
the docrace setup is for sale. if someone in middle east wants it.
  • 2019-11-26 18_43_13_Map-6.csv
  • 2019-11-26 18_43_31_Map-6.csv
  • 2019-11-26 18_43_45_Map-6.csv
  • 2019-11-26 18_44_01_Map-6.csv
  • 2019-11-26 18_44_18_Map-6.csv
Bnks334
530
344
Looking at the first log: (18-43-13) Avg IGN is showing as 7.9. Doesn't that mean the car was pulling 8* of timing, on average (knocking aggressively)? This was 5th gear and you were at about 2-4* of timing on each cylinder and cyl 6 was at 0* timing. Is the tune targeting that low of an ign timing or was it really pulling 8* of timing? Everythign else other than timing looks ok to me (temps, AFR, boost, throttle, etc).
Looking at the last log: (18-44-18) The car is doing what looks like a 3-4-5th gear pull. Like, out on the straight-away? Things look MUCH worse! 3rd and 4th gear look ok, but then look at what happens when you hit 5th gear... Timestamp 55.75...
The car is at 18:1 and even leaner afr. Pedal shows 100% but throttle is closed down to less than 40%. Not really sure what is going on here. There are only like 3 data points in 5th gear across a 7 second time frame? JB4 sucks. It almost looks like you are in a state of DECEL, but, it shows you are on the pedal still? Is this a glitch or something? Timing is showing 20*? This looks like a recipe for a blown engine, but, I t also looks erroneous so maybe everything was running ok here.
In 3rd/4th gear you were at 0* to 4* timing again, so, definitely knocking at the very least. Not what you want to see for a track tune. I run E85 (E30) on a 93aki tune so I can track with 0 timing corrections or issues.
Reactions: CNM135i and Asbjorn
Asbjorn
856
605
European, based in China
Z4 N54 DCT
Here's that log for others to study
Additional information
FirmwareInterfaceEngineTMAP_VAvgIgnDWPMethTriggerModeFFMethSafeModeMethAddMethScaleMethPSIVINE85_SetupVFF_Offsetfuel_30fuel_35fuel_40fuel_45fuel_50fuel_55fuel_60fuel_65fuel_70
19/2//1JB4 Android A281F Series - ALL1.967.962048009924.0¥￿ᅰXEF491515NONE0454550505050505052
BoostSafetyPID GainAutoShiftRedFuel_OLFUA1st_limiter2nd_limiter3rd_limiterFUDN20_TMAP6CylModeLastSafetyduty_15duty_20duty_25duty_30duty_35duty_40duty_45duty_50duty_55duty_60duty_65duty_70
25.8166060021.00.00.0NONE105303030302832353841454546
Reactions: houtan
Asbjorn
856
605
Z4 N54 DCT
Maybe this is where the engine gave up? The log:
19/2//1JB4 Android A281F Series - ALL1.977.962048009924.0¥￿ᅰXEF491515NONE0454550505050505052
Asbjorn
856
605
Z4 N54 DCT
Log number 4, the biggest file, just for reference
19/2//1JB4 Android A281F Series - ALL1.978.062048009924.0¥￿ᅰXEF491515NONE0454550505050505052
Asbjorn
856
605
Z4 N54 DCT
Done! Will obtain some new data from the track next weekend.
I promised data, but made the mistake of turning off the pump before entering the track. Will try to get some data next weekend instead.
In the meantime, some pics:
CNM135i
60
18
M135i PWG
The best picture taking the King for a spin is missing. Please correct! :grinning:
Asbjorn
856
605
Z4 N54 DCT
As mentioned elsewhere, in the last log, oil temp reaches 302F / 150C while coolant is only at 224F / 107C. Power reduction starts at 298F / 148C oil temp, which might explain the timing reduction. I am also surprised how oil is overheating sooner than coolant on this setup. Maybe the turbo wasn't water cooled?
Also there's no yellow cluster warning until 156C for oil. At least not on N54. For coolant it happens at 120C.
Long live the king
houtan
653
333
135i N55 DCT; PS2
In addition to what the others have already mentioned, why are you running a bootmode OTS map and a JB4? If you have bootmode, why not just go flash only and get an e-tune (unless bootmode has a PS2 OTS map, which i guess would be fine but an e tune would still be better). If you want to use the JB4 for some reason, don't they still provide a flash map to use with their HW?
Mterkait
26
Kuwait
F30 N55 '13
Looking at the first log: (18-43-13) Avg IGN is showing as 7.9. Doesn't that mean the car was pulling 8* of timing, on average (knocking aggressively)? This was 5th gear and you were at about 2-4* of timing on each cylinder and cyl 6 was at 0* timing. Is the tune targeting that low of an ign timing or was it really pulling 8* of timing? Everything else other than timing looks ok to me (temps, AFR, boost, throttle, etc).
The car had good power, and I didn't feel a lot of power reduction I mean of course it will pull timing due to high iat, but I don't feel the knocks like the sensor :S, yes the car died at the last log. (obviously :D). yeah, I could've used a better fuel or reduced the boost target.
I have stock setup for oil coolers so nothing improved in this dept, my car has one oil cooler on pass-side not two like US 335i, also i have csf radiator and intercooler.
The turbo is 6266 precision which is only oil cooled.
I'm not running JB4 anymore. not sure where did you read that. the flash is very good, except the coldstart is rough although its on OEM Setting. it became rough and bouncy after flashing their transmission tune idk why.
houtan
653
333
135i N55 DCT; PS2
All of the logs you posted are from a JB4. Do you have any logs running flash only?
Mterkait
26
Kuwait
F30 N55 '13
I never ran flash only on docrace setup as it requires mac solenoid to control the wastegates, and that was the main reason I had to have a JB4. MOTIV Boostbox isn't out yet for N55.
Asbjorn
856
605
Z4 N54 DCT
Alright, did some testing with @CNM135i two days ago at Zhuhai International Circuit. Semi-dry oil sump was turned on properly this time... However still saw oil pressure dropping from 95 to 70psi in one left hand corner.
Wasn't even running slicks, so not feeling very happy about this result...
F87Source
332
152
Canada
2017 Bmw M2
Do you have any track logs or video capturing the G forces for each turn? Just curious how many G's it took for your sump to start loosing oil pick up.
I kind of want the M4GTS or M4cs sump for my m2 since it adds another half a quart of oil which results in it being rated for 1.4 lateral G instead of the 1.2 found on the regular M2 + S55 sump.
Asbjorn
856
605
Z4 N54 DCT
Here is one corner where it typically happens. What you see in the log is trail braking into and then coming out of the left handed hair pin, the one shown in the picture below. It is not so much the peak G-forces, but rather the sequence of G-forces that starts the party.
So it mainly happens if turning left right after braking. Hence why I was trying to run a pump to return oil to the pick up area from the front of the pan during braking.
Afaik the only difference between GTS and non-GTS S55 oil pans is that the GTS runs a longer oil level sensor, so that it reports normal oil level when in fact there's 0.5L more oil than normal.
On the M2 N55:
675
So the M2 has the solution of the "dual oil pump" system with a baffle. One feeding the other. Great solution.
For the N54 actually i figured ppl sharing only the VAC baffle option.
What i cannot find and am planning to do somehow is to check the bolt pattern from the N55 Oil Pan and the N55 Bead Plate.
It may be a bigger DIY project but connecting the second oil pump to the n54 primary pump should be doable. Maybe even the M2 solution fits to the N54 bead plate?
The M2 Oil Pan has everything needed for that and with some hole adjustments it should be possible to fit the Pan to the N54.
Has anyone ever compared these component against each other?
Bnks334
530
344
N54 and n55 share the same oil pan IRC. The one issue though is the m2 uses an electronic power steering pump whereas the n54 and e-n55 use a hydraulic power steering pump which mounts on the oil pan.
F87Source
332
152
Canada
2017 Bmw M2
it's also near $1,000 so not the cheapest solution, this is not including the pump either and all the stuff required to make the pump work.
Overall I am pretty glad I traded in my m235i for my m2, alot less headaches to deal with when building it for the track.
F87Source
332
152
Canada
2017 Bmw M2
On the M2 N55:
Interesting, realOEM shows a different part number for the GTS and non-GTS oil pan so I am not sure if you're totally correct. The training manual for the GTS also notes the use of a different pan as well.
If it is indeed just a standard S55 pan + 0.5 L of extra oil then that would be very interesting, but I am worried that would fill the pan way too high and cause the crank to slap the top of the oil causing windage which is even worse than just leaving the oil as is.
I'll do more reading on this, but it is very interesting if it is indeed the same pan.
F87Source
332
152
Canada
2017 Bmw M2
Nope you're incorrect, I just checked and the oil level sensor itself is the same P/N as used on all the S55 and N55 motors: https://www.realoem.com/bmw/enUS/pa..._GTS&mg=11&sg=10&diagId=11_5919&q=12618638755
It is the oil pan that is different:
