10 Second Club - N54 Edition
Status
Not open for further replies.
AD-ENG
122
140
How far away can 9's be once the ADe 8.8's start being installed?
8.8 won't net you ET. It is merely a supporting mod for the power and abuse at the track.
The 4l80e kit on the other hand is an ET dream. Donnie ran his 10.9X at 21psi on his second his with no boost by gear and 17s. Lots and lots of potential there.
1.6X 60' just grip and rip on the foot brake.
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
2015 M3, 2008 135i, 2009 335i
Looks like Shiv is the only 6MT on this list? And a 1.7 60ft with a single turbo?!
I need some tips! These manual transmissions are really hard to shift without bog.
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
Raise your limiter and install a wotbox.
Gotcha. I have 2-step/NLS via JB4 relay right now. Had it set to 4K RPM and snapped an axle when I dumped the clutch. Looks like he has it around 5.5K in his video and lets the clutch out slower. I should try that with better tires. My best 60' was 2.0 with a 12.2 @ 123mph on stock turbos. Now I'm ready to test out my MMP Stage 3s at high boost.
cityazndan
108
14
2016 340i xDrive
Nope. Im on stock axles and open diff.
Oh yeah? I see you have pre LCI with big pumpkin, I have LCI so small pumpkin and slightly tapered axles so im a bit concerned what will happen on upgraded hybrids
Venom77
36
27
Arizona
335I
Im picking up more mph on the back half than a few of the slips up, I need to get my launch down. Hopefully this winter Im on this list.
Reactions: dyezak
4,342
The current record car by @Jack335i
Stock Block
Custom single turbo kit
Gtx35 with a 69mm compressor wheel and 9 blade rear wheel
2 speed powerglode rated at 1300hp
Modified tail shaft
Custom port injection kit with split second controller
46mm precision wastegate
Jb4 with mhd BEF
B&m pro racquet shifter
M3 control arms
bilstein coilovers
quaife lsd
Custom FMIC/CP
Dave@Fuel-It!
121
102
IL
2010 e92 335xi
Pure 2s
Fuel-It! DIY PI
Fuel-It! Stage 2 Bucketless
Burger Motorsports JB4 + OTS Hybrid/PI BEF
Status
