700 HP Club - N54 (Dynojet ONLY)
Status
Not open for further replies.
d8rknight
33
30
Tampa, FL
10' 335i , 15’ E400
737whp 674.82 dyno jet SAE smooth5
4th gear @ 29psi
2007 335i
Stock N54
6 speed MT
Spec Stage3+ Steel fw
Vader solutions S3 Pump
AD-E PI
Jb4
BCP intercooler
Vrsf charge pipe
Jp works kit
6266 gen 1
Video of my car on dyno is in this video (beginning of it )
I wonder if i were to let my controller learn the car more so than just changing on the fly if my numbers would read higher. I know on the street it's def more. Your car is bad@ss boss.
  • Love
Slow335is
89
Minneapolis Minnesota
www.youtube.com
Single turbo 335is
Can you please add us to the list. our shop car at European Automotive Performance MN just set the BMW 335is World Record. Was 94 degrees 44% humidity. Just so hot wasn’t worth pushing it. 715whp 733wtrq 100% Stock 6 bolt N54 motor. Was 31psi tapering to 29psi on a small Precision 6266BB Gen 2 1.0AR. E50 Fuel . Ran 40psi on the street and will dyno in the fall in cold weather on higher boost. Will attach in car footage and the datalog. Video in the comments and log is linked below. Car traps 140mph in the 1/4 mile full weight 3,850lb with me in it. Thanks WedgePerformance for the tuning and Moh's Performance Motorsport for the dyno. Be sure to check us out on YouTube SLOWBMW335is. Instagram is EAP_MN
JMVELA
67
23
2012 335is
world record. That is not a world record
JMVELA
67
23
2012 335is
This was done over a year ago on 93 oct pump gas and methanol port injection at 29 psi. Car is also a 335is stock engine twin MMP turbos
JMVELA
67
23
2012 335is
Funny it’s never been posted anywhere also awful torque number. We can strap it down and make more if you want.
I can also strap mine down and do more, hahaha.I left it there since it was enough for what I was looking for that day on the dyno. That was done on 93 oct pump gas with meth at 28-29 psi of boost. I still need to see how much we can get with ethanol. So we can also squeeze a lot more power. In regards to you comment of “awful torque numbers”, I was not looking for torque numbers that day, I was starting my pull on the dyno at high rpm to avoid putting to much load an my transmission clutches. So be humble and don’t presumed to much kido!!Be humble and people will recognize you more, just my two cents.
Btw, congrats on your achievements 😉
Status
