What's Everyone's Take on this Lockdown Brace
Rcboosted2007
902
90
Parts unknown
07 335i
So i ordered the defiv style off dejan. Works great. Install was fast 30min or so. And also a plus is it doesnt get in way of custom exhaust work or diff service etc
JStock_BTN54
19
12
Essex County NJ
RIP Defiv. His shop was very close to my house, very nice guy. It's a shame he got fed up with this platform as he made some pretty great products like the lockdown (which is the best style) and the first port meth plate years before anyone else.
How much is the knock-off going for?
I lucked out and got Rick’s 2nd one as a early adopter. One of the best mods I’ve done to my car.
1,630
How is the aforementioned lockdown brace different from the one Steve Clark sells? https://www.clarkperformancefab.com/products/differential-bracket
1,630
It’s all about thread context, my friend.
And I could have been clearer, so I edited my post accordingly:
Edit: “How is the aforementioned lock down brace different from the one Steve Clark sells.
Thanks.
dyezak
1,767
1,518
Plano TX
335is
Thanks.
Well, there are two different kinds talked about in this thread plus the Clark brace...so I'm still unable to answer that q. I can say one of them are functionally the same with a different design. They lock down the brace the same way. The other is a more complex design that is supposed to allow rotational movement of the brace but not axial movement. It is more expensive (by far) and that level of complexity is overkill due to the design of the rear subframe (IMHO).
But I'm not sure as to which of the aforementioned braces you are referencing ;)
ccbsecu
191
140
135i
Don't you think the Defiv style the OP posted is better then the other one posted that I quoted?if they are both the same price?
I am using the one I posted - on both my 135 and my 335d. I’d highly recommend that brace because it’s made from a solid piece of metal.
FWIW - The 335d makes over 700 wtq and the 135 will make over 800 wtq.
1,929
664
No...the sub-frame itself is isolated from the chassis with squishy as hell rubber bushings. You can even put in solid diff mounts and experience absolutely no additional NVH.
I already have whiteline poly sub frame bushings that why I was asking cause in my case I would think that I would transfer gear wine through my bushings since aren't factory
