DIY Silent Twin Plate Clutch UniClutch
1,686
Thought id throw in my 2 cents.
Did a manual swap on my 335d and decided to use the uniclutch track with a smf. Can confirm it chatters, loud enough to hear it through the centre console. Have to raise the idle rpm to 850 to quiet it down a bit. Sounds like a semi truck at low rpm.
I think it will be quieter with a n54 but i dont think it will get rid of it completely.
Awesome feedback
Would definitely be quieter with a N54. As an owner of both M57 and N54 engines the M57 is definitely orders of magnitude worse in terms of chop chop chop.
EX0PIL0T
15
Too many burnouts. Bye bye factory clutch. Just ordered a clutch and MFactory SMFW. Should be in by the end of the month, I'll get videos of the chatter, but with any luck it will be like this supra.
Reactions: Brule
Brule
393
464
335i 2007 6spd manual
Nice!
All cars seem to be very quiet or cant hear anything.
Glad you bought one the others suck.
Brule
393
464
Update : Around 530hp mainline hub or 600hp on dyno jet you will get false knock and missfires on a oem dmfw. If you are under 500hp its ok.
You need a single mass over 530hp is what I found
Reactions: EX0PIL0T
florida2002m3
12
I just upgraded my turbos. Currently working with tuner. Should be 550+wtq/hp once done. I know my 335is/550i clutch will start to slip as we turn up power, so I am planning ahead. My DMFW is definitely fried, making all sorts of noise for the last year or so.
As such I plan to go SMFW (steel) with UniClutch
A few questions:
What SMFW did you go with?
I am thinking Turner or Mfactory.... priced about the same, similar weight.
Since the Uniclutch (all dual plates) dont rely on the flywheels friction surface, could you use an old/used (not resurfaced) SMFW, bringing price way down?
The PN you listed "UC0821200" is for their "track" clutch. I couldnt find any options for their "sport" clutch on their website..... is "track" the only available option for our chassis?
Or since the "track" is only ~$100 more for 300 ft lbs than the "sport", with the "same pedal feel"..... no one bothers with the "sport"
Not a lot of info on these guys (new to market), the simple response of "google it" doesnt seem to work with this setup...... I appreciate your help!
EX0PIL0T
15
A few questions:
I went with mfactory since I have one of their differentials and it’s been great. Turner customer support is absolute horse shit in my experience so I’d never buy something as important as a flywheel from them personally.
I also reached out to UniClutch before I ordered and they don’t recommend anything other than the track clutch for these cars due to the torque produced. They still drive almost the same. Watch the video I linked in my last comment. The guys Supra has a single mass flywheel and the UniClutch track.
The ‘google it’ response isn’t really common here. Spool street hasn’t been infested with snobs yet thankfully
Reactions: jzx_andy
florida2002m3
12
Thanks for the info. Did my first log last night. 335is clutch slipped in 4th, then an hour later in 3rd......... the good news is that even with a base tune (w/o meth) its producing more tq than my strung out tune with meth on the old snails. Bad news: gotta spend more $$ on a clutch/FW.
I will likely rock the same setup as you (assuming the mfactory comes in 6 bolt.
florida2002m3
12
Interesting thought, could you use a flywheel from an automatic? I would think that there might be some driveshaft differences.... negating the cheap/easy reason to use a flex plate.
Did you have to play around with any spacers during your install? Or did they send you specific instructions to bolt it up to an n54?
EX0PIL0T
15
Mines been stuck in shipping purgatory because it was routed through china. I swear this happens every year with something. Anyways I was thinking the same thing. I really want to use the slg dct flywheel, but since my car is barely drivable at the moment that will have to wait for the next replacement
florida2002m3
12
Where did you order from? I plan to order from LMPerformance. They are USA, I am USA... so I hope they dont drop ship from overseas.
EX0PIL0T
15
Uniclutch directly. You can order from other suppliers like napa, but I'd rather not have a warranty for a clutch of all things go through a third party as they stated would happen in emails. Either way, only UniClutch and some less than glowing ebay sellers had the fitment kit so that was a no brainer too.
florida2002m3
12
Got the clutch yesterday (along with all the other maintenance parts), just in time for the weekend.
Ordered the mfactory flywheel. Ecs was $50 cheaper than everywhere else. Guess what part Im waiting on? Flywheel. Shoulda known better, I had hoped that Ecs had changed :(
Kahnzill
Good data to hear.
Do you have a video you can put up of the noises?
What flywheel did you use?
Have do you like the drivability?
Using a TTV flywheel. Its a little bitey at low rpm and alot of vibrating goes thought the drive train at slower speeds or high gear high load. But when you running through the gears its smooth and fantastic cant fault it.
Theres a company i found recently called PTB that sell upgraded DMFs gonna look into it when i have the money. Ive linked their website below.
Brule
393
464
Wow! Thats worse than the motiv/spec twin plate I had.
Ill have to look up 335d to see how other twinplates are on diesels but to me that is not right being noisy and grabby.
The uniclutch was in no way grippy for me it easily can be used at idle to get moving smoothly.
Heres my spec twinplate on n54
Kahnzill
Using a TTV flywheel. Its bites hard at low rpm and alot of vibrating goes thought the drive train at slower speeds or high gear high load. But when you running through the gears its smooth and fantastic cant fault it.
Its drives fine. Better then 6hp with slipping clutchs. Had a DKM SMF kit on my 330ci and the chatter was like a whisper. Was a big surprise on the e91. Ive been told diesel have alot more resonance and its normal with an aggressive clutch and SMF flywheel. i asked uniclutch if the sport version would help and they recon ot wouldnt handle the torque so looking at PBT racing dmf.
1,686
Took quite a while for my twin disk (x clutch) to break in. Was quite bitey at first and became very livable over time. I do not like how high the engagement is on it or really how short the window is. Short engagement is typical of that kind of clutch though. I do not like how it has become louder in the 5y and 30k miles I've had it. It was silent at first. Now rattles a bit but quiet if I set idle to 900, silent again at 1k+. But it has been a good clutch/fw and never even blinked twice at what I threw at it.
Looking forward to my new secret sauce setup courtesy of Hydra.
sergio.banon
I've got a manual swapped 335d as well and have been running into clutch problems with my setup. Are you still active on here for a few q's?
easy60
30
14
Not to bring a thread back from the dead, but I HATE my spec billet SMF and Stage 3+ Clutch, it sounds horrific at idle, pedal feel is brutal in traffic, just incredibly unrealistic, my buddy has talked me out of a twin-disk as he has had very poor experiences with them in the past. This may be just what I need.
1,686
Email Hydra.
Reactions: easy60
