My wife often asks me "what are you doing to that car now?" or words to that effect....also a few people have asked me "what mods have you done to your Zed?"
Today was a long wet and windy day..so I thought I'd try and remember some of the things that I've done to this "Yellow Peril"
I'm sure I've forgotten a few..hopefully a few items for inspiration?
1 | Zito 935s 235/40 18 265/35 18 Michelin PS4S | |
2 | Front HALO angel eyes LED upgrade | |
3 | Remove silver slats from lower grills | |
4 | Reverse colours on valance and rear diffuser | |
5 | Gloss black Kidney Grills | |
6 | Inlet port walnut blast | |
7 | Mahle air filter | |
8 | Dyno check 347 BHP 505Nm | |
9 | 2022 Map upgrade | |
10 | Bluetooth s/w upgrade | |
11 | MHD V9 stage 1+ 390 bhp 560 nm | |
12 | xHP stage 1.2 | |
13 | NGK coils | |
14 | NGK 1 stage colder plugs | |
15 | Uprated oil thermostat | |
16 | Redline ester based engine oil and Mahle filter | |
17 | 6 pot Brembo BBK front grooved /drilled | |
18 | Uprated anti roll bars front and rear | |
19 | Replacement parking brake motor | |
20 | Engine bay strut tower brace | |
21 | Zimmerman drilled / vented rear discs | |
22 | Colour matched calipers Phoenix Gold | |
23 | Catless down pipes | |
24 | 437M alloys with Michelin PS4s | |
25 | Limited Slip Diff | |
26 | MHD V10 stage 2+ 408 BHP 655Nm | |
27 | xHP stage 1.3 | |
28 | Uprated HID bulbs | |
29 | Revo boot rack | |
30 | DCT aluminium deep sump | |
31 | DCT oil and filter changes | |
32 | Aluminium oil filter cap | |
33 | Uprated suspension | |
34 | Removal Adaptive ECU plus coding | |
35 | Monoball bearing for front suspension arms | |
36 | Evo 1 Intercooler | |
37 | Z4 and 35is badges deleted | |
38 | M3 E90 RTAB upgrade | |
39 | Gloss black roll over hoops | |
40 | 437Ms refurbished in gloss black | |
41 | E90 M3 front Suspension arms | |
42 | Colour matched rear carbon fibre boot spoiler | |
43 | Centre speaker upgrade | |
44 | Door card speaker upgrade and door tweeter | |
45 | Rear shoulder speaker upgrade | |
46 | Rear centre speaker upgrade | |
47 | Rear brake lights LED upgrade | |
48 | Rear reversing lights LED upgrade | |
49 | Pierburg alloy water pump + Mahle Thermostat | |
50 | LCI side repeaters in gloss back | |
51 | Retrimmed and flat bottom steering wheel | |
52 | Later flappy paddles one sided action | |
53 | 5mm front wheel spacers | |
54 | Arc 8 19" 8.5j 35 and 9.5J 33 | |
55 | Michelin PS4s fitted to Apex arc 8 in satin black | |
56 | Arc 8 refinished in gloss black | |
57 | 245/35 19 275/30 19 Sports Contact 7 | |
58 | Meyle HD toe rods | |
59 | Index 12 injectors | |
60 | Stage 2+ DME re-map | |
61 | Stage 2 TCU re-map | |
62 | Stage 1 colder plugs | |
63 | B58 Ignition coil kit | |
64 | Uprated steering tie rods | |
65 | Later all metal water pump | |
66 | Adjustable toe and camber plates | |
67 | Adjustable rear camber arms | |
68 | Alignment done | |
69 | New rear boot struts fitted | |
70 | Garmin 57 and Mini 2 dash cams fitted | |
71 | Fox centre and rear exhaust system | |
72 | TTE 500 Hybrid Turbo Upgrade | |
73 | Uprated turbo outflow pipes | |
74 | Uprated turbo inlet pipes | |
75 | Uprated charge pipe | |
76 | Uprated 450 lph LPFP | |
77 | Wagner EVO 3 FMIC | |
78 | Forge diverter valves | |
79 | Uprated GUIBO | |
80 | Uprated centre shaft bearing | |
81 | Tuning for new hybrids | |
82 | Pipercoss panel filter | |
83 | Dyno test day 502 BHP 683Nm | |
84 | Footwell woofer upgrade | |
85 | New boost controller solenoids | |
86 | Carplay adapter | |
87 | Carbon fibre wrapped interior trim pieces | |
88 | Retrimmed gear gaiter | |
89 | Replaced snap in tray with general tray | |
90 | New set of 437Ms | |
91 | 437m refurbished and finished in graphite grey | |
92 | 235/35 275/30 SC7s fitted to 437m | |
93 | Brembo HP front pads | |
94 | Rear adjustable toe in plates | |
95 | Uprated RTAB and rear linkage bushes | |
96 | New aligment less rear camber better toe | |
97 | LED lights for map reading, boot, puddles | |
98 | New G29 Z4 and M50i badges | |
99 | Refitted turbo oulet pipe silicon hose + heat shield | |
100 | Mr.5 Inlet modification |
